Old 07-24-2009, 08:49 AM   #1
DJW88
Member#: 192301
02 WRX
Default kyb agx for gc8 on 02 wrx sedan?
i bought some used kyb agx struts from a member on here, the rear strut part numbers matched up with the wrx part numbers, but the fronts came back for 93-01 impreza struts, will these fit my 02 wrx sedan?, any help is appreciated.
DJW88 is offline   Reply With Quote
Old 07-26-2009, 07:49 PM   #2
DJW88
Member#: 192301
02 WRX
bump...
Old 07-27-2009, 12:24 AM   #3
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I believe it will fit, but you have to use the GD top hats.
That's how the GCs are, using GD struts, but have to use the GC top hats.
Smoke is offline   Reply With Quote
Old 07-27-2009, 10:05 AM   #4
DJW88
Member#: 192301
02 WRX
ok that makes sense, after some searching it seems like they will fit, but not a direct bolt on, anything else i need besides the tophats and possibly having to ziptie the brake lines? i'm gonna be doing the install this wkd so i wanna gather all the parts and info im going to need
Old 07-27-2009, 10:17 AM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
AFAIK they will fit fine with your original 02 springs and tophats - lots of 02-03 wagon folks used that exact combo (GC front / GD rear) to work around the camber loss associated with GD sedan struts on the narrower track of the GG. On the GD, you *should* pick up some negative camber in the front.
The stance may be a little bit 'off' - not sure the GC strut length / lower perch location is exactly the same - but I may be talking out of my arse on that.
UkNuck is offline   Reply With Quote
Old 07-27-2009, 03:40 PM   #6
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Camber-wise, you'll end up about the same as the sedan. Back in the day people thought that using the GC struts on wagon would be fine because of the similar front track. They were wrong. The lower clevis holes are in different locations up front, with the GC's being pretty close to where WRX sedan holes are. So, no benefit there. The rear's were even worse. Using the GC strut on the wrx resulted in massive amounts of neg camber. IIRC the lower spring perch of the GC front was lower than the WRX. Not 100% sure on that.
WRX Wagon front (orange) vs GC STi AGX (pink)
Rear
Arnie is offline   Reply With Quote
WTB: KYB AGX for GC8 blix666 NESIC Private Classifieds 0 04-03-2008 06:25 PM
KYB AGX for gc8 ASpec818 Private 'For Sale' Classifieds 3 02-12-2006 11:30 PM
FS: rear kyb agx for GC8 suberstar 2.5 Private 'For Sale' Classifieds 0 07-06-2005 10:39 AM
Cusco rear strut tower bar for gc8 fit 02 wrx sedan? jparent33 Brakes, Steering & Suspension 2 06-20-2005 03:33 PM
KYB GR-2 or KYB AGX for Rally-x Eclipse/WRX 66666 Brakes, Steering & Suspension 3 10-11-2004 07:23 PM
