Old 05-01-2002, 09:38 AM   #1
willguidry
Member#: 16388
Angry Starting Car. Isn't normal.
When starting my car after it has been sitting for awhile(either in the morning or after work) the car sounds like its gonna turn over right away, but I have to keep the key turned for what seems to me an excessively long time to turn over an engine. Makes the whirl-whirl-whirl-whirl-BOOM-engine on, but the "whirl" continues for quick some time before the BOOM. If I start my car after I've been driving, the car starts mint.
2000, 45k miles
Bought car @ 42.5k miles.
Haven't changed anything engine wise. Am getting my COBB CAI within this month, so I haven't replaced the air filter yet just cause it doesn't make sense to spend 60+ dollars for a KN that won't be in there long. The car was giving complete maintenance before I bought it, and was Subaru Certified. So, I would think that is the car needed plugs and filter, that they would have swapped them out. I am wrong?
But it may have nothing to do with either of these things. That's why I'm posting here.
Cheers
William
willguidry is offline   Reply With Quote
Old 05-01-2002, 12:07 PM   #2
jeffg
Member#: 2958
2001 6.0?RS
Okay so here is what I think:
assumptions:
car only has problems starting after it sits for a while.
car always starts, but it takes a while.
guess:
When the car sits for a while the fuel has the chance to run back into the tank. When you turn the car on, and crank it, it takes a minute for the fuel pump to build up pressure so the injectors work. This problem would be accented by a dirty fuel filter, or partially clogged lines.
Have you ever changed the fuel filter in the car? Try changing the fuel filter and when you get in the car, turn the key to on, not cranking, for a second or two, then turn the key to crank to start the car.
See if that helps.
Jeff
jeffg is offline   Reply With Quote
Old 05-01-2002, 01:58 PM   #3
willguidry
Member#: 16388
Will do Jeff,
Thanks
And no, I haven't changed the fuel filter yet.
Cheers
William
Old 05-01-2002, 08:51 PM   #4
DoinkMobb
Member#: 3787
2008 Gay
Car
Just curious, how would one change a fuel filter anyway?
DoinkMobb is offline   Reply With Quote
Old 05-02-2002, 12:23 PM   #5
Jademonkey
Member#: 9213
2000 RS
Red
This was posted in this forum...
http://www.northursalia.com/m...int/maint.html
It show's ya how to do everything. Basically, you can let your car sit overnite, to reduce fuel pressure, take off hoses, remove old filter. Install is reverse of removal.
Jademonkey is offline   Reply With Quote
my car isn't starting Wookie768 New England Impreza Club Forum -- NESIC 39 02-06-2010 05:51 PM
Jump Battery but car isn't starting! Jawknee5 Electrical & Lighting 3 10-07-2009 07:12 PM
Ironic baby naming isn't normal... Neek Off-Topic 16 06-02-2008 03:25 PM
@#$%@#$! Car isn't starting after install.. elemental Car Audio, Video & Security 3 09-10-2001 02:25 AM
My car isn't starting.. Alternator? Bahumut Normally Aspirated Powertrain 26 08-31-2001 10:20 PM
