Old 07-24-2009, 02:30 PM   #1
Forcedinduction
Member#: 216421
2002 WRX Wagon
red
Default Does anyone use or recommend using ZDDPlus?
I think I am going to join the Bob is the oil guy website. I have too many oil related questions which need answers.
I am interested in knowing if anyone is buying ZDDPlus in the 4 oz bottle and adding it to their oil. It does not seem like a bad idea considering what I have read. I realize ZDDP is bad for catalytic convertors so I do not want to talk about that, but rather it's effect on engine protection.
What I want to know is if adding a bottle of ZDDplus to my oil will increase ZDDP levels, thus offering better protection for my engine.
Forcedinduction is offline   Reply With Quote
Old 07-24-2009, 07:22 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
I have not used it and have over 100,000 on my engine via my right foot. If you are planning on keeping your car for 900,000 miles, I'd research it. If not, research mitochondrial DNA or something worthwhile as nothing in a bottle is as good as consistent oil changes.
Old 07-26-2009, 10:16 PM   #3
Forcedinduction
Member#: 216421
2002 WRX Wagon
red
Gee thanks. So very informative.
Old 07-26-2009, 11:10 PM   #4
sleeperrex
Member#: 19466
2002 wrx/hybrid
I posted this in another thread.
Don't see any reason for us to be runing it.
Don't have flat tappet cams.
http://www.hotrod.com/techarticles/e...ech/index.html
Alot of the buick guys use ZDDPlus, but then again GN's have flat tappet cams.
sleeperrex is offline   Reply With Quote
Old 07-27-2009, 08:54 AM   #5
Forcedinduction
Member#: 216421
2002 WRX Wagon
red
That's an interesting article. I read about basically the same thing a few years ago. I always knew rotella was good oil. I am gonna do a search and see if I can't find out how much ZDDP is in the current Rotella. Does any one run dino rotella 15w-40 in their WRX?
Old 07-27-2009, 09:05 AM   #6
z&cobb
Member#: 12344
2002 2JC
blue
A little info is given in the link. ZDDP is good for breaking in a new engine. Perhaps a little bit over the concentration in the new "improved" catalyst friendlier oils, may be OK for very severe service.
http://ezinearticles.com/?Why-the-Fu...DP?&id=2090427
For me, even M1 5w-30 works, even though it's a low friction, short life synthetic oil, but I use other additives with it; not ZDDP. It's my long term experiment beginning in 2001. So far so good, against other turbo engines falling by the wayside despite better oils and longer change intervals. One case never proves anything within a complex situtation. I have even seen Amsoil fail on an extreme change interval reported in the Nasioc files.
z&cobb is offline   Reply With Quote
Old 07-27-2009, 10:08 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
care to share that bit with us???
Old 07-27-2009, 01:27 PM   #8
z&cobb
Member#: 12344
2002 2JC
blue
Ultra high molecular weight, low concentration, polyisobutene/neutral base oil which is mandated under the CA GREET carbon dioxide reduction program for diesel fuel. Along with Torco MMT in 93 octane pump gas.
Up to 8% of the manganese oxide ends up in the motor oil. In that sense it is a dilute oil additive. It is known to be an effective oil spill absorbant it that field of application. I am beginning to think that is not necessarily bad. Most of the rest goes out the exhaust, and that doesn't seem to be bad as indicated in the early MMT tests conducted at SWRI on catalyst and oxygen sensor life.
The polymer works through non-linear kinetic effects. This is complex rheological and combustion science.
The Torco is there so I can always stay away from detonation with a spritely tune. According to the Torco blending chart, it is a bit over 96 octane.
Old 07-27-2009, 06:42 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
so...in laymans terms
it is an almost certanty that you havent blown it up using m1 oil is that you dont get any detonation, by using FUEL additives, that pounds the bearings to **** and causes spun bearing failure
And THAT is the REAL issue
Old 07-27-2009, 09:40 PM   #10
bluesubie
Member#: 767
04 FXT
Old 07-28-2009, 10:05 AM   #11
z&cobb
Member#: 12344
2002 2JC
blue
I think so too. Detonation is much worse than any oil is good.
The recent destruction of an 05 na Legacy engine (one daughter's anniversary edition) doesn't seem to fit the pattern about detonation though. It wasn't on synthetic oil either, much less M1.
In the na 05 automatic transmission Legacy case, M1 5w-30 cannot be blamed; it was done routinely at a shop, according to the Subaru specifications in the owner's manual. Perhaps no oil is much worse than detonation is much worse than any oil is good.
Meanwhile, I just keep on rollin along., keepin my eye on the ball.
Does anyone know or recommend a window company? I need a bay window replaced. higgins14 New England Impreza Club Forum -- NESIC 3 07-15-2008 04:23 PM
Does anyone know the font used in the subaru logo? flystiguy14 North West Impreza Club Forum -- NWIC 8 03-13-2007 10:37 AM
Does anyone have a checklist used for operating equipment? ToddZ199 Off-Topic 18 02-07-2007 12:01 PM
Does anyone know how to use helicoils or other thread repair? slim speedy Mid Atlantic Impreza Club -- MAIC 32 02-03-2003 03:50 PM
('93-'01) Does anyone notice that when using synthetic oil on a RS Jimmy Impreza Forum 16 05-15-2001 08:56 PM
