Old 07-24-2009, 06:31 PM   #1
1FSTREX
Member#: 109348
05 STI
CGM
Default Need Help: Broke a bolt off in the chassis and its stuck!
***UPDATE***
- The bolt is stuck in the chassis of the vehicle in the forward sway bar mount hole next to the fuel inlet pipe.
- There was a drill bit stuck inside of it
So i decided i would cut the bolt around the drill bit with a hack saw. This worked and the exposed portion of the bolt fell off leaving a portion of the drill bit exposed. I used a pair of vice grips and twisted the drill bit out. I tried again to use some extractor bits but unfortunately the hole is offset to one side of the bolt and not centered so the extractor bit wouldnt work. I was going to try and drill a new hole inthe center but unfortunately i couldnt get to the center of the bolt, because the other hole already covered the center. I decided finally to just try and drill out the bolt, only to find out that the hole already drilled was extremely slanted and i ended up drilling into the side of the mount hole. So now the hole is f***ed. No there is no happy ending to this story.
Basically now all that i can think of to fix it is to take it to a shop and have them take off the inlet pipe, drain the tank, drop the tank, remove all the charcoal crap, and then do one of two things.
1-drill out the rest of the bolt, get a helicoil and drill a hole for that to fit into and do it that way.
2-drill out the rest of the bolt and then get the threaded portion of a bolt that will fit through the hole on the cobb sway bar mount and then weld that threaded bolt to the chassis so instead of the bolt going through the cobb sway bar mount and screwing into the chassis. the sway bar mount actually slides over the bolt on the chassis and then gets locked on with a nut. Make sense?
Any other ideas out there?
Shop suggestions?
Etc?
F...M...L!!!!
Hey guys,
So im an idiot and i broke the head of a bolt off and the bolt is stuck. The bolt is located on the rear of the car, its one of the sway bar mount bolts and happens to be the one right next to the fuel inlet pipe. I believe the bolt is cross threaded and is extremely jammed. It gets worse, i tried to use a bolt extractor and accidentally broke off the drill bit inside the hole i was drilling. I have tried vice grips, pliers, and drilling the drill bit out and nothing is working. So i am basically in all kinds of ****.
So here are my questions:
- any ideas on how i can get the bolt out?
- any ideas where i can take it to get it removed?
- can i drive my car to the shop without the RSB on it?
Thanks guys,
Will
1FSTREX is offline   Reply With Quote
Old 07-24-2009, 06:51 PM   #2
steeter
Member#: 47632
2013 WRX 4dr
Dark Grey
I would use heat, then depending on how much of the bolt is visable....pic?
I might take an air chisel and square off the bolt to get a better grip with a wrench, pliers etc...again a pic would be nice.
Any shop that you trust.
Sure, just take it easy.
steeter is offline   Reply With Quote
Old 07-24-2009, 07:02 PM   #3
1FSTREX
Member#: 109348
05 STI
CGM
Thank you great response, my only concern with the heat is that the bolt is right next to the fuel tank and the fuel inlet pipe.
I am at work so i can get a picture when i am home. The problem with flatening it out is that there is a hole in it now where the hole was drilled for the extractor, so if i shave it i will have a knotch taken out of it.
Will
Old 07-24-2009, 10:37 PM   #4
Horkus
Member#: 112667
2002 WRX wagon
Get yourself a carbide bit on an angle grinder, grind off that drill bit, then when you see the normal bolt material, continue on using a new drill bit and be careful this time until you get the whole bolt out, use a tap clean out the threads and hope you didn't mess up the thread too much.
Horkus is offline   Reply With Quote
Old 07-25-2009, 01:34 AM   #5
1FSTREX
Member#: 109348
05 STI
CGM
Pretty much what i tried to do, didnt work i just made more of a mess of things. update
Old 07-25-2009, 01:48 AM   #6
EROC263
Member#: 96887
I agree a pic would be nice but if you could drill it out to where it would just be a hole in the frame, you could use a rivet nut. It's basically a threaded insert that pinches itself in the hole.
EROC263 is offline   Reply With Quote
Old 07-25-2009, 01:11 PM   #7
1FSTREX
Member#: 109348
05 STI
CGM
Thats what i am thinking i will do, only problem is the hole is right next to the fuel tank inlet so i am not sure if i can do it properly without removing it. I think its time to just get it fixed professionally.
Old 07-25-2009, 03:17 PM   #8
Horkus
Member#: 112667
2002 WRX wagon
I think this is a real challenge for the pros
Exhaust drone, vent holes in the trunk, and sound absorption ... need input Hokie-wrx wagon Interior & Exterior Modification 15 07-11-2013 07:36 PM
Its the last Friday of the year, and I'm stuck at work Thread Revision Mid West Subaru Owners Club Forum -- MWSOC 28 12-28-2007 07:17 PM
I need help! Broke a bolt! rsteckly Newbies & FAQs 10 10-09-2007 03:06 AM
help: car shuts off in the middle of the road 1sloREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-14-2006 11:45 AM
broke a bolt off of turbo , what to do ? billy boi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-04-2004 11:42 AM
