Old 07-24-2009, 05:34 PM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Cam dowel pin removal
Anyone have some tips on how to remove a dowel pin without destroying it or where I can get a new pin for a cam? I need one for a cam I am installing and have several sets of wrx cams that are worthless so I figured I'd pull it from one of them if possible.
thanks
Mike
LiquidForce is offline   Reply With Quote
Old 06-16-2014, 04:16 PM   #2
bizarro252
Member#: 336417
2008 STi
this thread is older than dirt but FYI to anyone else searching for this, I got mine out by using a can of air turned upside down to freeze the pins and then they pulled out easily with vice grips.
Now - anyone know where to get a hold of NEW pins?
bizarro252 is offline   Reply With Quote
Old 01-20-2015, 04:45 PM   #3
Keleios
Member#: 187581
Resurrecting this post.
Does anyone know what the part number is for the Cam Dowel Pin? (SOHC EJ25 but I bet it is the same on for others )
An exhaustive search of parts.subaru came up with nothing. It isn't in any of the part diagrams.
It is hollow, with an 8.5mm outer diameter and a length of 12mm.
Keleios is offline   Reply With Quote
Old 01-20-2015, 06:08 PM   #4
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
no sure on PN
But if anyone else searches for this, best way is to tap the dowel and use a bolt, washer and a smaller socket the bolt goes thru so you can pull them out without any damage
Old 01-20-2015, 07:24 PM   #5
jam007
Member#: 174706
2008 LGT-B
What about chilling it?
jam007 is offline   Reply With Quote
Old 01-20-2015, 08:30 PM   #6
Paul
Member#: 56203
00 RSTI Coupe
NM...read it wrong thought it was dowels in block
FIDANZA Flywheel: Two dowel pin holes instead of three? WTF Trunk_Monkey Transmission (AT/MT) & Driveline 11 12-22-2010 05:05 PM
how important are dowel pins ? Serkan Transmission (AT/MT) & Driveline 6 11-24-2009 01:34 AM
Cylinder head dowel pins Do_It_Sidewayz Built Motor Discussion 6 08-27-2009 11:49 PM
Missing a dowel pin... dmross Transmission (AT/MT) & Driveline 2 02-16-2009 04:32 PM
Dowel Pins? STI 6speed swap. AWNOPEEL Transmission (AT/MT) & Driveline 3 05-18-2008 03:18 PM
