Old 12-16-2009, 08:46 AM   #126
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Did you guys tighten your spark plug gaps down .028 was too big for my setup , I had to tighten them down to .023-.024 .... I think it was spark plug blow out from the e85...
TDagen is offline   Reply With Quote
Old 12-16-2009, 03:52 PM   #127
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
^I think this would fix your above 28 psi high rpm problem... Mine ran fine until I turned the boost up...then at higher rpm 6000+ it would look like it was knocking or misfiring but it was just my spark blowing out from the e85....
Old 12-16-2009, 03:53 PM   #128
cnstman
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
he tried a set gapped to .018. Did not fix the issue.
cnstman is offline   Reply With Quote
Old 12-16-2009, 05:33 PM   #129
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
In theory would this set-up work with a stock ej207 twinscroll header... I.E. Could I have a custom rotated uppipes/wastegates blah blah made to fit the stock header?
prokaw875 is offline   Reply With Quote
Old 12-16-2009, 06:57 PM   #130
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Perhaps its an issue with coil pack dwell time settings in the AEM. I have witnessed these to be off on the evo's and wouldn't be surprised if they were on subaru's as well.
I would check those next.
Okada upgrades wouldn't be a bad idea either.
project_skyline is offline   Reply With Quote
Old 12-16-2009, 07:35 PM   #131
cubuff
Member#: 38345
2004 WRB WRX
Thats what im being told as well. Im going to get a set of known working good coil packs and then some irridium plugs and adjust dwell. I was originally led to believe you cant adjust coil dwell but I have been told by multiple people now that you can. So thats up next on the list. Im going to get a few miles on the car now then go back for more tuning in early february.
The only thing about the okada coils is that they are $600+ and for that price I might as well well for Spark Tech to release their subaru options.
cubuff is offline   Reply With Quote
Old 12-16-2009, 11:16 PM   #132
RYNOMOTO
Member#: 197147
2004 Subaru Forester
Java Black Pearl
I had to adjust the coil dwell in my motec m4 on my car to get it to rev above 7500rpm..... then, 37psi and 680whp was not a problem....
dwell is one of those weird things that people don't think of sometimes, and, the more power you make, the more all the little things matter.
Set the dwell time to the correct setting if you can first and you can check each coil for resistance across the primary and secondary to see if you have weak ones....
The other side to this is if the coils show the correct resistance, and you are able to correct the dwell time (if it is off some), you will know if you have the ignition strength to fire the mixture or not. If you don't, you will have to step up the amperage/Mj capability of the ignition system....
The thing is, with the power you have made thus far on stock coils and 28psi, I wouldn't doubt it if you are close to the end of what the coils will fire.... there is a tremendous amount of fuel volume difference to be ignited when going from Gasoline to E85......
Here is the other thing on spark plugs from an NGK engineer:
{what are the advantages/disadvantages of running a projected/nonprojected plugs in boosted applications?
also, does e-85 fule require a different heat range?}
The theory is that typically for street driven applications a projected insulator will be beneficial as it positions the spark farther into the combustion chamber promoting better ignitiability as it will be closer to the densest part of the mixture. at low speeds it also helps keep the firing end of the plug hotter preventing fouling. This is helpful in high power cars that run very cold plugs on the street. Also as the intake valve opens and the fuel charge rushes in the plug has a greater area being exposed so as to cool down more.
The only downside is that by putting the plug into a higher turbulence area you may also raise the required voltage needed to fire the plug. In very high boost cars this can lead to misfire (spark blowout), especailly with a weak stock type ignition system or over heating of the ground electrode at high rpms (because the ground path is longer), especailly with a weak stock type ignition system. This can sometimes be helped by switching to a fine wire type iriidum plug which reduces that voltage requirement back down and also lowering the plug gaps.
I have also heard from drag racers on a couple applications that they were able to run a non-projected plug and add in a degreee or two of spark timing and pick up some substantial horsepower increases.
So really I would say if it is a street driven vehicle try to run a projected plug. If it is a all out race car you may benefit from a non projected type plug (or if running nitrous). Of course this rule is not always valid as cylinder head turbulence, quench area, etc can sometimes change this recommendation.
Generally alchohols require a colder heat range to be fitted because they do not absorb as much heat when evaporating, causing higher cylinder temps. With E-85 though we have seen most applications requiring the same heat range. Just run the original heat range plug and be sure to check the appearance of the firing end after 50 miles street use or a couple drag passes. Hope this helps, thank you.
RYNOMOTO is offline   Reply With Quote
Old 12-17-2009, 01:29 AM   #133
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Dustin, your coils are dumb
They are not smart enough to to understand dwell
Junior2JZ is offline   Reply With Quote
Old 12-17-2009, 01:40 AM   #134
cubuff
Member#: 38345
2004 WRB WRX
I know those damn dumb coils, they just dont understand!
So on a serious note. Subaru coils are "dumb" meaning they rely on the ecu for dwell settings correct?
Old 12-17-2009, 01:59 AM   #135
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Call me tomorrow.. I will go over it with you.
Jr
Old 12-17-2009, 04:19 AM   #136
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
I say go for 40 psi.
Old 12-17-2009, 09:48 PM   #137
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Sorry I haven't posted the graphs yet- I forgot. I will try to post them tomorrow.
Drac9 is offline   Reply With Quote
Old 12-18-2009, 06:12 PM   #138
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
post post post
Full-Race Geoff is offline   Reply With Quote
Old 12-18-2009, 07:20 PM   #139
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Lets see that graph!
Old 12-20-2009, 06:02 PM   #140
garagedefeat
Member#: 101399
2001 Forester L
this thread is useless without the boost turned up
garagedefeat is offline   Reply With Quote
Old 12-20-2009, 11:14 PM   #141
RYNOMOTO
Member#: 197147
Java Black Pearl
AMEN!!!
haha....
but, you gotta keep a spark lit if you are going to make power at high boost...
...much easier said than done.....
Old 12-21-2009, 10:48 AM   #142
garagedefeat
Member#: 101399
2001 Forester L
Originally Posted by RYNOMOTO View Post
AMEN!!!
haha....
it *should* light off if you don't rev it to the stratosphere. Unless there is an actual problem w/ the ignition system.
Old 12-21-2009, 06:06 PM   #143
Darkhrse99
Member#: 214903
Dustin,,
How's your car running? I didn't see you at Jeff's this weekend to check the car out.
Darkhrse99 is offline   Reply With Quote
Old 12-21-2009, 06:18 PM   #144
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Care to elaborate on this? It's my understanding that alcohols have a much higher heat of vaporization, and AFR. Both would produce a cooler charge upon vaporization/evaporation. However, alcohols have a significantly lower HHV, ie, less heat energy is released per mass during combustion. Just going through some numbers for ethanol and methanol vs gas, and the total energy from the HHV compensating for the AFR is slightly higher for ethanol, and even higher for meth. This would explain both the need for colder plugs on most alcohols, with similar ranges between gas/e85.
Merp is offline   Reply With Quote
Old 12-22-2009, 12:52 AM   #145
RYNOMOTO
Member#: 197147
Java Black Pearl
Hey Merp....
That was a quote from an NGK engineer, not me.....
....Sounds like you pretty much answered your own question though, or am I misunderstanding what you are commenting on or asking about?
I think an NGK #6 or #7 will work well with an E85 combo....
Old 12-22-2009, 09:25 AM   #146
Merp
Member#: 199106
Patches on OEM ECU
Hey Merp....
Whoops, missed that part.
It's somewhat of an answer to the question, but what I'm unsure of is the effect of the cooler charge on combustion temps vs the higher hhv output as they occur in different areas of the motor. I've heard people say hotter plugs due to the cooler charge, so this caught my attention.
I've used 6's and 7's on e85, and had bad blowout on 7's with a big gap, and went to 6's with a small gap with better results, but didn't have a chance to try out the 7's with a small gap before the motor imploded (seems unrelated), so my personal research is still inconclusive.
Old 12-22-2009, 10:22 AM   #147
RYNOMOTO
Member#: 197147
Java Black Pearl
I think E85 is really a very unique fuel to tune sparkplugs for....
I haven't personally had any E85 tuning experiences, so everything I have on it is quoted from others experiences....
I do know that regular alcohol race engines with very,very high compression like to run very cold plugs.... I know and understand that....
I have always heard it said that a person should select the proper heat range of plug for the horsepower of the engine, but, again, I do not know if that falls in line here....
I know that I run NGK #2309's (#7 heat range iridiums) in my 04 FXT with a mildly tuned S/R 50 turbo at 15psi and it makes 275whp on a Mustang dyno, and my plugs don't foul with pump gas all the time....
I end up usually replacing the plugs every 30,000 miles or so....
and I have 160,000 miles on the stock coil packs..... but again, this is not trying to light off the fuel volume and cylinder pressure in a combination anywhere close to Dustin's...... with it taking so much more fuel volume to reach the proper air fuel ratio, I believe it is straining the ignition system's capable power more than it is an improper spark plug selection.
I believe if there was an issue with a crank trigger, it wouldn't rev to 9000+rpm..... especially with 24+psi of boost....
I still think it is dwell related or basic ignition system power related....
It will take some dwell adjustments, and it may take a CDI ignition with better coils to fire off the mixture....
remember, all of the guys running alcohol in big V8's cannot do it on a stock or an hei ignition, same for the guys with LS1's with Coil per cylinder ignition..... they make stronger than stock coils and stronger ignition systems for those engines also....
If you think about the logics of it, Cubuff's engine is making somewhere around 150-160 horsepower PER CYLINDER...... at 28psi of boost....
If it were a V8, it would be making somewhere around 1200-1300 horsepower at the crank..... Now, how many V8's with stock ignitions do you know that can light off 1200-1300 horsepower running alcohol and 28psi of boost?
puts it more in perspective about why he might be having problems.....
Old 01-12-2010, 02:23 PM   #148
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Pump for them dyno graphs drac9!
Old 01-12-2010, 06:28 PM   #149
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
I was too but they never have been posted....
Old 01-20-2010, 11:34 PM   #150
Drac9
Member#: 9861
This was the cleanest pull I could find:
my new body kit on my 04 STI EuroScuby Off-Topic 12 11-08-2007 01:27 PM
Do I need anything extra to mount my new body kit? kingpin950 Interior & Exterior Modification 4 09-08-2002 08:20 PM
pics of my new body kit!! WRX D.A.R.E. North West Impreza Club Forum -- NWIC 2 07-15-2002 12:01 PM
Pictures of my new body kit! ImprezedRS Member's Car Gallery 14 04-29-2002 11:11 PM
