07-25-2009, 07:42 PM | #1 |
Member#: 216135
Vehicle:2011 |
First oil change....wowser
So I did my first oil change as a Subie owner (1000miles). I decided to keep the Toyko Roki filter on there for one more short OCI with PYB (1500-2000miles) so I didn't remove the engine cover since there is that hole near the drain plug. Anyway I've been doing 100% of the maintenance/repair on my Honda since highschool and the same on my wifes vehicle(s) since I knew her. However, never have I removed the drain plug on a car and have the oil drain out with such intensity that in the split second my hand is still in the way, the stream of oil is sprayed my hand and diverted ALL OVER THE GARAGE floor. Additionally, my empty 15 qt oil pan (those common black large ones with a little hole in the middle plus a breather plug on the side and the handle like drain on the outer perimeter) damn near overflowed since the 4.2qts came out so fast that it couldn't drain into the pans middle hole fast enough. Suffice it to say, I was not prepared for that . I guess one thing I will do next time is NOT remove the oil filler cap before I open the drain plug in hopes it will slow the flow out of the drain plug. Anyway, am I the only one with this observation?
I guess it might be fumoto valve time?
07-25-2009, 08:58 PM | #2 |
Member#: 36144
NESIC
Vehicle:2010 Legacy2.5GT Ltd Graphite Gray Metallic |
07-25-2009, 09:32 PM | #3 |
Member#: 216135
Vehicle:2011 |
Wow, you read my mind. I roughly chaulked that out while I was under there. I need to get a wrench though. That filter is not conducive to a thread off with your hand like my Honda's were.
07-25-2009, 10:38 PM | #4 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Between our 2 Subies we have over 250K miles, that's a lot of oil changes and I never use a wrench on the oil filter. |
07-25-2009, 10:56 PM | #5 |
Member#: 153954
BAIC
Vehicle:2007 Impreza 2.5i SE Black |
I have also used one of those drain containers with a single small hole in the middle..... only once haha. Even with the oil filler cap on, it still drains out too fast. The best is a drain pan with the large-diameter screw-on top with a plastic net to catch the drain plug when it falls.
Oren |
07-27-2009, 12:43 PM | #6 |
Member#: 73043
Vehicle:2019 STI/370Z/Jeep Black/Black Cherry/Green |
I've got the same oil drain pan. This car comes out a LOT faster than my old WRX. If I didn't know better, I'd have thought it was pressurized!! Oil on my hands, driveway, ramps, and I also thought it was going to overflow the drainpan. I must have looked like a monkey humping a football under that car!!! RP
07-27-2009, 12:49 PM | #7 |
Member#: 175549
Vehicle:2007 Forester STi 1965 Shelby Cobra (F5) |
definetely get the Fumoto valve. It's so nice to not worry about breaking or rounding the bolt, avoiding the oil stream, buying crush rings, re-torquing correctly and finding the right wrench/socket. Just flip open, wait, flip close.
Just did my first oil change/gear oil change since i got my car | ayobreezie | Newbies & FAQs | 12 | 07-19-2006 08:29 AM |
First oil change and first time to 6000rpm | chirp the 1-2 | Newbies & FAQs | 22 | 06-12-2006 09:52 AM |
First oil change! = What oil do you use? | Italiano | New England Impreza Club Forum -- NESIC | 7 | 05-07-2003 07:13 PM |
