Old 07-26-2009, 10:17 AM   #1
WRrexu
Member#: 217061
2009 Wrx
Default 245's on 09 wrx ?
stock tire siize on the 09 wrx is a 225..... come next summer i want to have a wider tire for appearance and a little more traction. will i have any rubbing issues with 245s on stock wheels ?
WRrexu is offline   Reply With Quote
Old 07-27-2009, 12:45 AM   #2
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Discount tire shows the 245/40/17 will fit without issue.
08EJ25 is offline   Reply With Quote
Old 07-27-2009, 01:43 AM   #3
WRrexu
Member#: 217061
2009 Wrx
would most nasioc people trust discount tire do you?
Old 07-27-2009, 07:23 AM   #4
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
245 is pretty wide for the stock 7" wide wheel, it's not recommended, just from the wheel/tire combo side of things.
If you can stick your finger between the tire and the strut, you should be good.
Remember, going to a 245 only adds 10mm of extra width on either side. If you get some wide summer performace tires, it might be a little more.
dbrier is offline   Reply With Quote
Old 07-27-2009, 02:15 PM   #5
mosc
Member#: 177401
2004 STi White
16G powered lagless fun
Problem with switching to 245 wide is that you'll likely want to drop your sidewall from 45 to 40 at the same time. 45 handles widths better than 40. 245/40/17 needs 17x8" where 225/45/17 needs a 17x7" rim. Increasing your tire width that much and dropping the sidewall means you need a substantially wider rim.
225/45/17 = 17x7.0" min
245/45/17 = 17x7.5" min
225/40/17 = 17x7.5" min
245/40/17 = 17x8.0" min
09 WRX stock rim is 17x7.0"
mosc is offline   Reply With Quote
Old 07-27-2009, 09:06 PM   #6
WRrexu
Member#: 217061
2009 Wrx
yeah thanks for the info guys much apprieciated , i think ill just get better summer tires and some nice perrin sway bars for next summer and i should be set handling wise
06/07 wrx calipers on 09 wrx jsham109 Brakes, Steering & Suspension 8 05-04-2010 04:39 PM
Who's running 245's on their WRX? penderperson Autocross 48 07-27-2009 10:40 PM
Will 08 STi srpings work on 09 WRX? S2kVer02 Brakes, Steering & Suspension 4 12-17-2008 01:50 PM
08 STi springs on 09 WRX ? Brack Brakes, Steering & Suspension 0 12-12-2008 10:34 PM
03 WRX wheels on 09 WRX? Rmetz1 Newbies & FAQs 9 10-21-2008 09:48 AM
Message Board Statistics All times are GMT -4. The time now is 12:16 AM.
