Old 05-01-2002, 01:02 PM   #1
PURE EPI
Member#: 2642
Question the next thrilling installment...
After much toiling I have found that i did not blow yet another MAF. however, the OBD code I pulled when I got the part said a low voltage from the throttle position sensor. I d/c'ed the battery and reset everything and the car will run fine. before that it did the dreaded "MAF hesitation" at 3200-4000 RPM. Has anyone else experienced a problem with this sensor? I adjusted the throttle cable to take some slack out of the cable, and Buster helped remove the silencer.
Any ideas?
thanks
christian
PURE EPI is offline   Reply With Quote
Old 05-02-2002, 10:52 AM   #2
fab9joe
Member#: 12466
1999 2.5rs
silverthorn metalic
in havent heard it refered to 'maf' hesitation. subaru technical service bulletin #11 58 99 recommends replacement of ecm. it also has been refered to as a knock sensor sensitivity issue. now you are telling me it is a maf issue? argh! - i have had this problem on and off for a year now.
fab9joe is offline   Reply With Quote
Old 05-02-2002, 02:08 PM   #3
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
The hesitation is the knock sensor, I fixed mine by putting a small gasket under it. 1200kms and it is not back.
RageHardIntoTheBendies is offline   Reply With Quote
when is the next install day in the HR. hydramist, and 07 tranny and diff help needed moorebl Mid Atlantic Impreza Club -- MAIC 4 06-16-2008 09:00 PM
What Kind of Driving Gives You The Biggest Thrill? Tang 06 i wagon Impreza Forum 85 09-01-2006 10:46 AM
the next Indy Install Day IndySport Mid West Subaru Owners Club Forum -- MWSOC 75 06-18-2003 08:05 AM
Can't wait for the next "FreeBMW install day?" Safir Mid West Subaru Owners Club Forum -- MWSOC 0 10-25-2002 11:50 AM
whens the next BAM/install fest? subaruwrx Bay Area Impreza Club Forum -- BAIC 14 01-11-2001 10:14 PM
