Old 07-26-2009, 10:28 PM   #1
rsemrad
Member#: 135250
2006 WRX TR
Default 5x100 bolt circle
I am struggling to find a bolt circle called out for 5x100 pattern.
Have tried to calculate this based on measurements but I don't trust the results as the geometry doesn't jive.
Is there a credible source for this informaton?
Thanks,
Semrad
rsemrad is offline   Reply With Quote
Old 07-26-2009, 10:55 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
whatthe****areyoutryingtofigureouthere?????
Old 07-26-2009, 10:59 PM   #3
ZoneMaster
Member#: 215979
2006 WRX Limited
I'm a bit confused what you're asking exactly, but maybe this may help?
http://www.tirerack.com/wheels/tech/....jsp?techid=92
-Cory
ZoneMaster is offline   Reply With Quote
Old 07-26-2009, 11:52 PM   #4
rsemrad
Member#: 135250
2006 WRX TR
Default bolt circle
The lug pattern as called out 5 x 100 does not represent the circle drawn through all five lugs. It is a measurement from the back side of a line drawn from two adjacent lugs to the center line of the opposite lug.
In theory one could take the centerline distance from the two adjacen lugs, the distance from back side to centerline and calculate the bolt circle. My math isn't working out.
Why do I want this information? Just purchased a set of Volk GR-C wheels and must machine spacers for them...........need the bold circle to determine x, y locations for each hole to machine.
Semrad
Old 07-27-2009, 12:36 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
you bought the wrong wheels
Old 07-27-2009, 01:42 AM   #6
ZoneMaster
Member#: 215979
2006 WRX Limited
If you're looking to get spacers purely to help with offsets, wouldn't it be easier and more cost effective to just buy some?
Don't get me wrong, I'm all for fabbing up stuff yourself, but spacers aren't really that expensive.
If you're set on making some, hold some aluminum plate up to the backside of the wheel and trace the pattern. A makita and some drill bits later you have a spacer.
As far as the math goes, I tried, but my brain shut off 3 hours ago. Sorry.
-CRY
Old 07-27-2009, 10:05 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
-CRY
he's trying to re-invent the wheel, I think
Old 07-27-2009, 10:46 AM   #8
garrett02bugeye
Member#: 218501
2002 wrx
world rally blue
i have oz superleggaras and they are awesome
garrett02bugeye is offline   Reply With Quote
Old 07-27-2009, 11:27 AM   #9
s203.22b
Member#: 113970
2005 STi WRB
2001 2.5RS AW
^^ lots of help that was.
The answer is ~R 49.42mm.
s203.22b is offline   Reply With Quote
Old 07-27-2009, 12:59 PM   #10
mosc
Member#: 177401
2015 STi White
Well, remember that 5x100 is not a circumference, it's the diameter. The actual circumference would be 314mm. The radius is 50mm. Now, I think 5x100 might actually not be 5x100 and instead be 5x4" which would be 5x101.6mm or a radius of 50.8mm and a circumference of 319.2mm. Not sure on that. 5x114.3 for example is exactly 5x4.5" so It makes me think these things are actually in standard and not metric.
mosc is offline   Reply With Quote
Old 07-27-2009, 01:00 PM   #11
rsemrad
Member#: 135250
2006 WRX TR
MOSC, the '100' in 5x100 is not the diameter. ZoneMaster references the Tire Rack as proof. However, life would be much simpler if it were......I would be interested to know where s203.22b got his number of 49.42mm
Old 07-27-2009, 01:04 PM   #12
mosc
Member#: 177401
2015 STi White
Wheels are the most bizarre combination of metric and standard imaginable with ratios for sidewall and non-standard hub diameters to boot. I think they do it on purpose to keep themselves in business. Too confusing to figure it out on your own so they get to keep their prices up.
Old 07-27-2009, 01:30 PM   #13
rsemrad
Member#: 135250
2006 WRX TR
MOSC,
Just took your radius of 49.42 and laid it out in CAD showing a pattern of 5x95.26
Does the industry round up? I wouldn't think so given the callout of 5x114.3.........
Old 07-27-2009, 01:44 PM   #14
mosc
Member#: 177401
2015 STi White
"Bolt pattern or bolt circle is the diameter of an imaginary circle formed by the centers of the wheel lugs"
-Tire rack
Sounds like diameter to me!
I don't know where 49.42mm comes from and I don't think it's right. Seems more likely 50mm or 50.8mm. Honestly, 0.8mm is pretty friggin small anyway.
Old 07-28-2009, 08:34 AM   #15
rsemrad
Member#: 135250
2006 WRX TR
Default It really is 5 x 100
Sometime being thick just creates more work..............
Ran the numbers again last night based on new measurements and shure enough! it is 5 x 100.................
FS/FT in NC: BBS RX 17 x 7.5, 5 x 114.3 bolt circle waldrm Wheels/Tires 2 02-16-2010 03:18 PM
2008 WRX bolt circle? Skobie Tire & Wheel 2 09-30-2007 11:37 PM
QUICK HELP...3" gasket bolt circle REX8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-05-2005 01:09 PM
volk racing te37 bolt circle size droolmonkey Off-Topic 17 05-10-2004 11:38 AM
conversion from 100mm bolt circle to 114.3mm? aspera Brakes, Steering & Suspension 3 01-12-2003 06:38 PM
