Old 07-27-2009, 12:28 AM   #1
RideHolden
Member#: 207584
2008 Lexus IS F
USB
Default Tire Pressure Light
Hey everyone. I saw the tire pressure light go off a few days ago and inflated the tires to 42 psi as suggested by the dealership when I last saw them. The problem I'm having is the tire pressure light is still showing. Is there something wrong with the car or is it perfectly normal for it to do this?
RideHolden is offline   Reply With Quote
Old 07-27-2009, 12:37 AM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....have you driven it around since you inflated the tires? Also, just how low were the tires before?
Old 07-27-2009, 02:07 AM   #3
RideHolden
Member#: 207584
2008 Lexus IS F
USB
Yeah, I drove about 200 miles after inflating them and the tires were in the 20s or mid 30s before i inflated them.
Old 07-27-2009, 11:35 AM   #4
Kean
Member#: 25187
'08 Foz Prem TGM
....hmmmm. If the light is steady (indicating low pressure), it should have reset by now (blinking would indicate a system issue). .....which you probably already knew and why you're asking these questions.
Are you still under the 3/36 warranty? If so, I would take it in and have the dealer have a look at it. It may be that the system needs to be reset or perhaps one of the sensors is faulty (providing a false reading). You can also do a bit of searching on these forums using keywords like "TPMS".
Here's a bit of info to get you started.... How it works:
http://www.cars101.com/subaru/tiremonitor.html
http://www.drive.subaru.com/Spr05_WhatsInside.htm
Tire Pressure Light Flashing DubyaSTi Tribeca Forum 3 11-17-2008 09:53 AM
08 Spec.b Tire pressure light after putting after maket wheels Taras Tire & Wheel 15 08-14-2008 01:11 PM
Tire pressure light in 2008 WRX Troa Service & Maintenance 9 07-06-2008 06:56 PM
new rims and tire pressure light on ornge04gt Newbies & FAQs 12 04-06-2008 10:33 PM
low tire pressure light wont go off Shootist Tribeca Forum 4 09-10-2006 06:12 PM
