Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 07-27-2009, 10:16 AM   #1
ForcedInductionPhool
Member#: 217930
2004 STI
Default Air Bag Light??
The car is a 2004 STI, I did not drive my car for a day and it just sat in a rainstorm all day. I got into my car to go to work today and noticed that the Air Bag light stayed on. I did a search on here to see what it could be but the only thing I would keep comming accross is a 3.3ohm resistor fix which I believe is for a 05+ with seat sensors. So my question is what are the more probable causes for this to stay on. Will a auto parts store scanner be able to pick up a code for it? Also as a side note my horn works perfectly and the CEL is not on (cruise is not flashing).
Thanks for any input.
ForcedInductionPhool is offline   Reply With Quote
Old 07-27-2009, 10:21 AM   #2
Mechie3
Member#: 120152
Mine does this. Check the connector under the driver seat. Sometimes they get a little loose, sometimes they corrode. Clean the connector and put it back. Mine will be on sometimes, off other times.
Old 07-27-2009, 11:14 AM   #3
Member#: 217930
2004 STI
Ok thanks I will check that out. Hopefully its just a loose connection. Anybody else have any suggestions?
Thanks,
Old 07-27-2009, 01:56 PM   #4
Member#: 217930
2004 STI
Well I went out and wiggled my yellow air bag wires under the seat and the next startup the Airbag light went off . I guess it was when I put the rear floor matt's in it must have worked them loose. Do you guy's suggest dielectric grease in the connection?
Thanks a bunch...
STI front side air bag & Resistor to fix air bag light 02WRX_BLUE Interior & Exterior Modification 3 12-29-2004 10:16 AM
Help! Deleted Seat Air Bags & used 3.3 Ohm Resistors & getting Air Bag Light 2.2gotboost Electrical & Lighting 3 02-19-2004 10:36 AM
Valentine One causing air bag light to go on? McLaren Formula 1 Tri-State Area Forum 8 05-30-2003 05:45 PM
air bag light Aspenwhite02 Interior & Exterior Modification 8 01-15-2003 11:51 PM
('93-'01) air bag. light???? bratmantlz Impreza Forum 3 02-22-2002 10:29 AM
