#1 |
Member#: 217930
E. Canada
Vehicle:2004 STI WRB |
The car is a 2004 STI, I did not drive my car for a day and it just sat in a rainstorm all day. I got into my car to go to work today and noticed that the Air Bag light stayed on. I did a search on here to see what it could be but the only thing I would keep comming accross is a 3.3ohm resistor fix which I believe is for a 05+ with seat sensors. So my question is what are the more probable causes for this to stay on. Will a auto parts store scanner be able to pick up a code for it? Also as a side note my horn works perfectly and the CEL is not on (cruise is not flashing).
Thanks for any input. ![]()
#2 |
Member#: 120152
Vehicle:2006 06 WRX, 86 FMOD Blue, White/Red |
Mine does this. Check the connector under the driver seat. Sometimes they get a little loose, sometimes they corrode. Clean the connector and put it back. Mine will be on sometimes, off other times.
#3 |
Member#: 217930
E. Canada
Ok thanks I will check that out. Hopefully its just a loose connection. Anybody else have any suggestions?
![]() Thanks, |
#4 |
Member#: 217930
E. Canada
Well I went out and wiggled my yellow air bag wires under the seat and the next startup the Airbag light went off
. I guess it was when I put the rear floor matt's in it must have worked them loose. Do you guy's suggest dielectric grease in the connection? Thanks a bunch... |
| Thread Tools | |
| Display Modes | |
| STI front side air bag & Resistor to fix air bag light | 02WRX_BLUE | Interior & Exterior Modification | 3 | 12-29-2004 09:16 AM |
| Help! Deleted Seat Air Bags & used 3.3 Ohm Resistors & getting Air Bag Light | 2.2gotboost | Electrical & Lighting | 3 | 02-19-2004 09:36 AM |
| Valentine One causing air bag light to go on? | McLaren Formula 1 | Tri-State Area Forum | 8 | 05-30-2003 04:45 PM |
| air bag light | Aspenwhite02 | Interior & Exterior Modification | 8 | 01-15-2003 10:51 PM |
| ('93-'01) air bag. light???? | bratmantlz | Impreza Forum | 3 | 02-22-2002 09:29 AM |
