Old 07-27-2009, 10:10 AM   #1
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
Default rolled the rally car 3 times
At the Nemadji Trail 3 stage rally I rolled our Open Light class STI 3 times. I had driven this rally 2 previous times (each rally goes over the roads multiple times) so I was familiar with stage. I just carried more speed through the 2 preceeding corners than I did in the past and didn't initiate my slide for the next corner accordingly (only 10-20 ft. too late). I also neglected to realized the roads were softer than previous races and that the cars before us would move all the soft dirt/sand/gravel to the outside of the corner. you can see on the out of car footage we are holding the inside line through the corner and are almost through it when the car starts backing away from the inside - that's when my right rear tire tapped the soft stuff and sucked us down. the ditch dropped away and we were going too fast too sideways at that point (65mph + ) and we went over. I didn't have enough torque (n/a motor) to get out of the soft stuff once it got hold of the tire. If you watch the in-car you see my arm come out during the first roll - I'm reaching for the shifter (where it used to be) to grab second to try and power out by didn't realize we were already going airborn (I immediately crossed my arms after that). You can also see dave's arm come up to shield his face as the windshield came through on his side).
this was a tough rally. mark utecht rolled the mustang as well and another driver took a tree in the right side just ahead of the B pillar.
our car is fixable and will be at ojibwe. it will be many colors
carl s. is offline   Reply With Quote
Old 07-27-2009, 10:15 AM   #2
sen7inel
Member#: 192602
Oh wow. You guys came out of this unscathed?
sen7inel is offline   Reply With Quote
Old 07-27-2009, 10:50 AM   #3
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
yea everyone from all 3 incidents came out ok. my codriver is going into the dr today to make sure he didn't crack a rib, I banged the hell out of my knee on something and am sore all over, other than that a few cuts from glass I'm fine.
Old 07-27-2009, 11:29 AM   #4
fliz
Member#: 30342
Glad to hear you're ok.
Who was the third off?
fliz is offline   Reply With Quote
Old 07-27-2009, 08:46 PM   #5
dch
Member#: 1057
2004 WRX STi
Very Yellow
That's a bummer Carl. Aside from carrying a bit too much speed for how the corner tightened, it looks like you were doing the right things. I'm glad you and Dave aren't too banged up, and I like the positive attitude (and those multi-colored cars for the right reasons)
Cheers,
-Doug
dch is offline   Reply With Quote
Old 07-27-2009, 09:27 PM   #6
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
Cheers,
-Doug
Hi Doug, yes I came in too hot - everytime I watch the video I see where I should have set-up for the corner. I set-up at the same point we were using at the past nemadji rallies but we were't carrying as much speed through the preceeding section as we were this time.
when graham is back from the x-games he'll replace the roof and the left fender supports. I think I'll also have him tie the cage into the A pillar now that it's easy to get to. everything else we'll be trying to get pounded out best we can. Picked up a nice yellow passenger door today.
I'm just very happy Dave and I are ok and that the car is still useable. This does sort of fudge up our coefficients since we'll end up at 17 after OFR and LSPR (assuming we don't have any more incidents) and probably won't have the funds to do Paris
Old 07-27-2009, 10:37 PM   #7
MatthewakaMatt
Member#: 190911
2005 9-2x Aero
Sorry to hear about your roll Carl, but at least you are okay and the car is salvageable.
MatthewakaMatt is offline   Reply With Quote
Old 07-28-2009, 01:49 PM   #8
dch
Member#: 1057
2004 WRX STi
Very Yellow
A yellow door, eh? That oughta be worth slightly more fractions of second per mile than a GEMS sticker.
The thing about turn-in points is they change all the time according to road conditions and tire wear. What was too early last time might be way too late the next time, but too early is usually a lot easier to salvage than too late. There's also the crossover point where if you're sliding the car around corners instead of aggressively attacking the corner with plenty of wheel spin you'll find that you tend to drift wider. Mr. Block seems to struggle a bit when he tries to back off, as an example. What worked best for me was more aggressive trail braking into the corner when trying to be cautious, then always attack it like you mean it once you've got the right rotation and position. Coming down a gear in a corner can be tricky, especially without a dog box because you can't rush the synchros. It's best to be in the right gear for the slowest part of the corner early, so you can brake in the corner (with your foot still on the throttle) to slow down and get a bit more rotation if you need to while keeping the power on. The difference in grip between sliding around a corner and powering around a corner is substantial, but you have to be totally committed. It's almost a leap of faith to make the transition, but you know when you get it right (as well as when you get it wrong). Seat time. All you need is more seat time...
Cheers,
-Doug
Old 07-28-2009, 02:04 PM   #9
wrxsomeday
Member#: 141991
14 FRS Ultramarine
16 Forester XT CWP
thank god for roll cages!
wrxsomeday is offline   Reply With Quote
Old 07-28-2009, 02:20 PM   #10
snowcrzy
Member#: 110895
Bummer guys . I have doors if you need them.
snowcrzy is offline   Reply With Quote
Old 07-28-2009, 02:24 PM   #11
topshark04
Member#: 172419
'15 Black WRX
Wow that's alot of damage. Good thing neither of you were hurt!
G/L on future events and hopefully you can make it to the Paris event!
topshark04 is offline   Reply With Quote
Old 07-28-2009, 02:25 PM   #12
digitalpimp
Member#: 40931
05 sport wagon
group 2 96 gti
note to self: pink strut tower bar less effective w/o bar.
digitalpimp is offline   Reply With Quote
Old 07-28-2009, 04:34 PM   #13
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
CARL!
man that sucks. I had some small damage from NEFR that im worried about getting sorted in time for Black River Stages, but that much damage in the time frame you are looking is crazy.
Good luck, git r' dun and rock out at Ojibwe. I wont be making it out after all.
_billy
RS22b is offline   Reply With Quote
Old 07-29-2009, 01:18 PM   #14
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
looks like the timing belt jumped 90 degrees or so... in the bad direction. turning motor over by hand did not feel like it had 11:1 pistons - guessing we bent the valves and maybe destroyed the pistons and head.
might be buying a second rally car after all
Old 07-29-2009, 02:07 PM   #15
dch
Member#: 1057
2004 WRX STi
Very Yellow
Bah! Just source a motor or have Whiskers rebuild it for ya. I don't think I have any more laying around, but if I do (ask Graham) I'll give you a hell of a deal on it.
And for Nick:
Cheers,
-Doug
Old 07-29-2009, 03:59 PM   #16
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
And for Nick:
Cheers,
-Doug
it looks like the passenger side cams are still aligned, only the driver's side lower cam has jumped. we'll see what happens tonight when we tear it down. I just hope we didn't damage our 11:1 pistons, that would be the biggest issue for finishing out the season in our Open Light car. Mason Moyle has been doing great in his car which still has stock cr but it's also a lot lighter.
I'll check with graham if it does come down to it - appreciate it Doug!
Hoping we can bounce back for Ojibwe and still have the funds to actually compete - we might make it up but not have enough to pay for the gas home (which is ok, I'll just bring my fishing gear)
Old 07-30-2009, 07:25 PM   #17
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
looks like the engine survived without damage!
repaired the rally car after rolling 3x carl s. Member's Car Gallery 6 08-23-2009 09:46 PM
Possible to get the hood they use on the Rally cars? mav1c Motorsports 46 01-20-2009 07:57 PM
The rally car is off the road...picked up an oldschool Legacy! Sean New England Impreza Club Forum -- NESIC 20 03-09-2004 03:37 PM
Finished painting the rally car...now I have to wait to put the VID pack on. Sean Motorsports 4 09-08-2002 11:26 PM
('93-'01) what is that chirping on the rally cars? E'scubi Impreza Forum 85 05-07-2001 03:04 PM
