Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-27-2009, 05:29 PM   #1
Scott_2.5TS
Member#: 163806
Default What endlink is everyone using with 27/29mm FSB?
You might say this belongs in the Suspension section, but i feel they're too many people in there that don't know what they're talking about... i shouldn't say that, maybe i'll get a better response in here
I prefer to get an answer from people who are actually using this product.
I have whiteline steel endlinks that shape like a figure 8, but i bent on of the bolts on there, should i just throw the stock endlinks back on? will they break??
Scott_2.5TS is offline   Reply With Quote
Old 07-27-2009, 05:56 PM   #2
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
I was using Whiteline's adjustable endlinks and never had them break. I did remove that bar though and switch to a smaller one after a few months of use. Here is a link: http://www.rallysportdirect.com/shop...ks-p-2626.html
-Colin
pinkertonpunk is offline   Reply With Quote
Old 07-27-2009, 06:06 PM   #3
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
I use the whiteline HD endlinks in the front with some extra washers for added strength. Haven't had a problem in I replaced the washers 3+ years ago...
xcdhridr is offline   Reply With Quote
Old 07-27-2009, 07:36 PM   #4
WFOSTI06
Member#: 196921
06 SUBARU
WRC BLUE
I started out using the helm joint configuration from whiteline with the larger whiteline bars ,the fronts made way too much noise ,until I used a stack of washers to space the end link from the suspension mounting points on the control arms ,as for the rears they worked fine until I switched to whiteline lateral links ,at which point I started breaking both ,2 end links at different times and both mounting points on the lateral links .To remedy the problem I fabricated new mounts on the lateral links and went with billet end links ,so far so good ,whiteline did replace 2 of the 4 lateral links due to failure but I built a better mouse trap you might say ...........hopefully they will last !
WFOSTI06 is offline   Reply With Quote
Old 07-27-2009, 08:10 PM   #5
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
I was using the Whiteline adjustable (heim joint) endlinks with the 27/29mm bar, and the first set lasted from April to about October before the nasty noises they were making made me say something to IAG about them. Evidently, the heim joints aren't the highest quality, and they go bad. IAG replaced them under warranty, and that weekend, I did the South Central Subaru Challenge event at Carowinds. On the way home, the endlinks were making crunchy noises already.
If I was still using a front swaybar, I would go with the Kartboy solid endlinks myself. But I took my car to ESP (SCCA classing), and I'm going front-swaybar-less for now.
CamaroFS34 is offline   Reply With Quote
Old 07-27-2009, 08:12 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Stock or Kartboy for us.
Tony
Old 07-27-2009, 08:50 PM   #7
Draken
Member#: 16
1968 Saab
Sonett II V4
I ran the stock 2004 STi end links for two years without problems. On both 275-17 Hoosiers for autox, and 255-17 track tires for time trials.
Chris H.
Draken is offline   Reply With Quote
Old 07-27-2009, 09:36 PM   #8
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
I'm using Poltec endlinks, but I was worried about fitment issues if I didn't use a spherical setup for the wagon (plus they came with the bar). I do get some nice popping noises over uneven bumps. Unfortunately, Poltec is no longer in existence.
flyboymike is offline   Reply With Quote
Old 07-27-2009, 09:37 PM   #9
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
yep Stock it was....they work most of the time
Old 07-27-2009, 10:33 PM   #10
penderperson
Member#: 172370
2006 STI
p.s. Colin(pinkertonpunk) rocks STU, any advice from him is good stuff!
I'm using the 'BIGSKY' endlinks, spherical with better fit and finish than whiteline, i love them(spherical endlinks) for three reasons.
a) they do not restrict motion like rubber-bushed endlinks preventing a smooth/linear force curve in bump/repound(allowing the swaybar to do its job)
b) they do not restrict motion like rubber-bushed endlinks that cause the suspension to loose droop travel(as important as any other ax suspension aspect)
c) they allow for easy adjustment when relieving preload for cornerbalancing
-Rob
penderperson is offline   Reply With Quote
Old 07-27-2009, 10:46 PM   #11
leecea
Member#: 37359
2003 WRX
When I researched this, the only brand for which I found no bad reports was Kartboy. I've run them on both ends for a couple of years and have had no issues. They are also cheap.
leecea is offline   Reply With Quote
Old 07-28-2009, 12:13 AM   #12
Splash
Member#: 55936
04 WRX STi
I ran stock ones for 3 seasons with my WL bars. I still run stock endlinks, just on COBB bars now...
Splash is offline   Reply With Quote
Old 07-28-2009, 05:16 AM   #13
Scott_2.5TS
Member#: 163806
I think the stock design/spherical is the best i've seen too
The bushing design isn't really working. I'm going to switch back to stock
Thanks guys!
Old 07-30-2009, 11:46 PM   #14
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
Im running cobb endlinks, I havent dared to put it on 29 settting yet.
Dubstar112 is offline   Reply With Quote
Old 07-31-2009, 09:14 AM   #15
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
Stock WRX links so far on the Perrin 25(actually 26)mm bar on the stiff setting. 235/45/17 kumho ecsta XS tires.
First race with the bar is this weekend. We'll see, it seems fine on the street.
MurphysLaww is offline   Reply With Quote
Old 08-04-2009, 10:00 AM   #16
Mechie3
Member#: 120152
I used kartboys for 2 years. Only problem I had was I didn't have the spacer so it ate through 1 set of bushings before getting a new set of bushings and a spacer (for free from TIC!!). I ran it on 29 and DD it.
I now use some heim joint endlinks (don't know the brand) that came with my 32mm niles bar.
Mechie3 is offline   Reply With Quote
Old 08-04-2009, 10:26 AM   #17
bpang1
Member#: 67225
2015 Audi S4
Red
I am using Helix spherical end links on my Wagon...feels good and seems to be holding up well. I always worry that the bearings will fail but they looked good last weekend when I was under the car changing oil.
Have been running them for 2 years but have only auto-x'ed maybe 5-6 times in that span.
bpang1 is offline   Reply With Quote
Old 08-04-2009, 11:51 AM   #18
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
My friend made mine. They are adjustable heim joint type. Larger thicker than anything you can buy, and only cost $30 to make! Yeah if I snap them I have better just pulled a bigger jump than Ken Block.... hahaha
RedefinedTR is offline   Reply With Quote
Old 08-18-2009, 09:06 AM   #19
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
One thing about the stock endlinks+Perrin 25mm bar, at least in my case, the left side bolt keeps coming loose. I'm assuming it has to do with how the bar twists, and the extended flange on the Subaru bolt which makes contact with the bar, eventually working the bolt loose.
Old 08-29-2009, 05:40 AM   #20
808subaru
Member#: 62234
Chapter/Region: HIIC
09 fozzy
Angry
Seeing as i'm the first to post with Hotchkis sways competition. They are 27mm F&R. They come with heavy duty endlinks, but recently i've had the bolts pop out of the lower point where it fixes to the brackat on the car.
They are good with a nice soft set of R-comps though.
P.S.- i have no idea why a mad face icon is over my post.
808subaru is offline   Reply With Quote
Old 08-29-2009, 09:02 AM   #21
racer580
Member#: 202667
2007 STi
OBP on Gold
^^^ at your mad face over the post
racer580 is offline   Reply With Quote
Old 09-04-2009, 12:35 AM   #22
elirentz
Member#: 70082
2014 FoST, 02 s2000
06 Cayman S, 80cc shifter
Stock endlinks on a the whiteline 27/29mm here too with 50k+ miles and tons of autox and track days without a problem.
elirentz is offline   Reply With Quote
Old 09-04-2009, 01:20 PM   #23
joltdudeuc
Member#: 6119
1999 GM6
RBP
I use these
joltdudeuc is offline   Reply With Quote
Old 09-16-2009, 10:14 AM   #24
SharkWagon
Member#: 99788
1977 Chevrolet
Corvette
I had the whiteline helm joint ones (this is on a wagon) but the clunk was driving me crazy as the car is a dd.
I put the kartboy solid ones on about 9 months ago and I am very happy with them.
SharkWagon is offline   Reply With Quote
Old 09-16-2009, 01:13 PM   #25
M3's R scooby snacks
Member#: 193431
2009 Rallitek-WRX
WR Blue
Running Rallitek's on the front of my DS car with their 25mm front bar. Over 100 autocross runs, including a Hillclimb win and Reg. Pro-Solo championship thus far this year. Couldn't be happier and great price.
Andrew
M3's R scooby snacks is offline   Reply With Quote
WTB: Whiteline 27-29mm FSB for STi !!! Needed quick !!! AndrewSS Private 'Wanted' Classifieds 7 07-14-2006 11:45 AM
Anyone running whiteline 27-29mm FSB? scobaru Brakes, Steering & Suspension 22 06-14-2006 09:07 PM
Whiteline 27-29mm FSB clunking? ScoobyTodd Brakes, Steering & Suspension 20 06-09-2006 03:46 PM
What EM is everyone using for JDM STI swap? xS2k Subaru Conversions 9 10-14-2005 04:24 PM
upgraded turbo, what restrictor is everyone using? MarkyMark Engine Management & Tuning 3 03-15-2004 10:53 PM
