07-27-2009, 05:44 PM | #1 |
Member#: 217307
Best way to fix oil leak
I had a diagnostic with my 2004 Subaru STi at IAG Performance and they told me there was an:
"Oil leak under timing cover...either cam seal or oil pump seal." IAG is over an hour away, and I am wondering if I can trust our local dealership www.sharrett.subaru.com in Hagerstown to find and fix the problem for me. Would it be cheaper or safer to take it to IAG or DNS Tuning to get this fixed? Is there anything I can do to maybe find / fix it myself?
07-27-2009, 07:13 PM | #2 |
Member#: 143624
NESIC
Vehicle:14 FXTT (hers) 15 Legacy 2.5i Prem (his) |
How bad is the oil leak? How many miles do you have? Maybe time for a timing belt change while you're in there?
IMHO I believe most dealers are more than capable of replacing a seal, but it's not about that. It's about who you trust, and who you believe will fully cover a mess up should one occur. |
07-27-2009, 09:26 PM | #3 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
Yes, definitely do the timing belt change. Try searching in the Mid Atlantic forum for dealership recommendations.
I'll get you started with this one. That's it! The first one is free and you have to pay for any others. -Dennis |
07-27-2009, 11:52 PM | #4 | |
Member#: 217307
07-28-2009, 08:51 AM | #5 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Frankly I wouldn't worry about it right now. When it gets closer to timing belt change time, do it then.
To do the cam or crank seals, you have to pull the timing belt which is not hard but time consuming. |
07-28-2009, 12:23 PM | #6 |
Member#: 143624
NESIC
+1. If you can't see a noticeable loss in oil level nor any leakage on the ground then it's not that bad. Change out the seal, if necessary, when the timing belt is due.
07-28-2009, 12:46 PM | #7 |
Member#: 173715
BAIC
Vehicle:2002 WRX |
+1 for depending on severity of leakage. Personally I wouldn't be able to drive another 30k miles knowing that my car is leaking, but every ones situation differs...
07-29-2009, 07:36 AM | #8 |
Member#: 217307
When is timing belt change time?
How to fix Oil leaking thru bolt threads? | MY2ND04WRX | Service & Maintenance | 3 | 11-23-2009 09:58 PM |
Best Way to fix a crack in polyurethane | westin_impreza | Interior & Exterior Modification | 5 | 11-19-2003 09:12 PM |
What's the best way to fix/repair minor scratches? | Zoso | STi Forum Archive | 3 | 08-30-2003 10:50 PM |
Best Way To Fix A Dent? | my WeRX | Service & Maintenance | 3 | 04-08-2002 07:50 PM |
Someone scratched my car. Best way to fix? | remarcable | Car Care & Detailing | 10 | 03-07-2001 01:16 PM |
