Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-28-2009, 01:37 AM   #1
DreadScourge
Member#: 201184
2001 WRX
Default Negative Camber on a Stock '09 Sedan
I got aligned today at Les Schwab. I told them to max out the negative camber and this is what I got:
The car is completely stock, suspension wise, but I had read on here about others getting up to -1.5 degrees on theirs. Just wondering what your thoughts are on this.
I plan on getting some camber bolts to get a bit more negative camber going.
DreadScourge is offline   Reply With Quote
Old 07-28-2009, 02:33 PM   #2
autoXsp33d7
Member#: 201282
2013 Subaru WRX
SWP (matte white for now)
i am getting 1.3 up front your guy did not try hard at all on this alignment that is for sure. i do know that i did my own alignment and it took about an hour and an half to get it right. You need to loosen all the bolts and max it out.
autoXsp33d7 is offline   Reply With Quote
Old 07-28-2009, 09:02 PM   #3
tuskenraider
Member#: 65699
15 WRX
WR Blue
Haven't seen anyone higher than -1.4(BIGSKY), who is now at -1.3 with the Koni Sports in. Loosened every related front bolt to get that I believe. I got -1,-.9 up front loosening the tophat bolts and push/pulling the loose assembly. You could definately get double that.
tuskenraider is offline   Reply With Quote
Old 07-29-2009, 12:54 AM   #4
DreadScourge
Member#: 201184
2001 WRX
Thanks for the replies. So should I loosen the bolts in the lower clevis holes in addition to the top hats? Or would I just be waisting my time?
Old 07-29-2009, 04:49 AM   #5
autoXsp33d7
Member#: 201282
2013 Subaru WRX
nope not a waste of time do it and you will see better camber that is for sure and read this forum there is alot of help for use 09 guys
http://www.clubwrx.net/forums/everyd...r-part-ii.html
OEM '02 WRX Wagon struts. Good for Koni doners. Add neg. camber on Sedan. daWagon Suspension/Brakes/Handling 5 02-25-2010 05:22 PM
Negative camber on stock suspension generalee69 Brakes, Steering & Suspension 19 05-01-2008 06:16 PM
More negative camber on a sedan using wagon struts Arnie Brakes, Steering & Suspension 4 04-01-2004 12:45 PM
negative camber on WRX stock rears? rex_ruthor Brakes, Steering & Suspension 1 08-25-2001 07:53 PM
