Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 07-28-2009, 07:35 AM   #1
Technological.ws
Member#: 201060
2008 Impreza STI 08
Both left wheels on my 08 STI have been stolen.
My insurance covers this. They are going to purchase 2 new STI wheels with Dunlop SP 600 tires (same as stock).
I know that I can't put the new tire and the old one on the same axle because it can hurt LSD. I'm going to put both new tires on the same axle.
The problem is that my current front and rear tires are worn slightly differntly. I don't know if it's safe for LSDs to put them on the same axle.
How much difference in tire tread wear is acceptable on the same axle with an LSD?
Will it really hurt the LSD if the thread wear difference is 2 mm?
Should I buy new tires even if the wear difference is little?
I have a helical LSD on the front and a Torsen unit on the back.
Which axle is it better to install the differently worn tires? I mean which LSD type is less sensitive for differently worn tires?
Many thanks for your help in advance.
Technological.ws is offline   Reply With Quote
Old 07-28-2009, 09:25 AM   #2
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
in order to avoid issues your remainign tires should have at the minimuum 7/32" tread depth. If they do not have the new tires shaved to match the old tires ....
Old 07-28-2009, 11:30 AM   #3
mosc
Member#: 177401
2004 STi White
16G powered lagless fun
I think your center diff would be the most sensitive with your setup.
What are the tread depth measurements on your tires exactly? What is the new depth? You have a maximum of 3/32" of leeway but ideally it should be closer than that.
mosc is offline   Reply With Quote
Old 07-28-2009, 04:59 PM   #4
Technological.ws
Member#: 201060
2008 Impreza STI 08
The tread depth of my two remaining tires are 15/64" and 17/64" (outer side near the center of the tread).
I don't know the tread depth of a new tire. I think that it's more than 19/64".
I'm not sure if I can find a workshop that can shave tires. I doubt there is one nearby.
What would you suggest to do?
Should I install all the four new tires?
Old 07-28-2009, 05:17 PM   #5
Jons_uurx
Member#: 189180
04 wrx jbp stg dos
03 Infiniti G35s
i have a friend with an 05 sti and his center diff. was locking up due to uneven tires, he bought 4 new tires and it went away.
Jons_uurx is offline   Reply With Quote
Old 07-28-2009, 05:31 PM   #6
mosc
Member#: 177401
2004 STi White
Buy 2 from tirerack and they'll shave em for ya ($). The 1/32 difference between your two existing tires isn't hurting anything.
Old 07-28-2009, 11:45 PM   #7
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
put the new tires on the back and done
Difference between 04 and 05 Prodrive STI springs GTScoob Brakes, Steering & Suspension 6 11-28-2006 11:24 AM
differences in VF39 and VF30 on EJ257 blueribbon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-08-2006 09:41 PM
different size tires and differential damage sregger Brakes, Steering & Suspension 14 02-27-2006 02:56 PM
Intake difference between '06 and '04-'05 STi? SirWilliam Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-15-2005 06:29 PM
HP difference between PE1820 and VF22 on 93 octane? Shaitiger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-29-2004 01:42 PM
