Old 07-28-2009, 05:11 PM   #1
beedee
Member#: 124727
Default 17x9 = death of wheel bearings?
i've done various searches but found bits and pieces, nothing solid though. has anyone had experience with destroying wheel bearings running a 17x9 +30 wheel on our cars? i know camber and fender rolling/pulling will come into play depending on how low i go, which wont be very low.
one vendor was saying that set up is horrible for our cars and i would be replacing my wheel bearings in about 6 months. so i wanted to see if anyone here has experienced that? i really like the concave look of the 9" wheels but if they are going to destroy my bearings, it wont be worth it.
beedee is offline   Reply With Quote
Old 07-28-2009, 05:36 PM   #2
grippy monkey
Member#: 131067
your "stance"
sucks
6 months... who is the vendor.. they are stupid.
Let me go down the list of some of the wheels I've had for you:
18x9.5 +22
17x9 +30
18x9 +35
17x8 +21
18x8 +23
18x8.5 +23
my car has 60k miles on it. I've driven it with low offset wheels almost since day one of owning the car which was 20k miles and 2 years ago. There is also a load of people with similar setups as mine that have been driving longer than me with no wheel bearing issues. The wheel bearings on our cars will wear a little faster than normal (maybe a few K over the life of the bearings), but having a low offset wheel isnt causing nearly as much stress on the bearings as a car that sees track use. Long story short the 6month thing the vendor told you is a lie.
grippy monkey is offline   Reply With Quote
Old 07-28-2009, 05:47 PM   #3
beedee
Member#: 124727
thanks for the feedback and wheel size examples grippy. this is exactly why i wanted to run it by the masses.
Old 07-28-2009, 06:20 PM   #4
mosc
Member#: 177401
2015 STi White
Rota makes 17x9" 5x100 with +42...
mosc is offline   Reply With Quote
Old 07-28-2009, 07:23 PM   #5
kaptainkevlar
Member#: 80109
07 spec B
[quote=grippy monkey;27585244] The wheel bearings on our cars will wear a little faster than normal (maybe a few K over the life of the bearings), but having a low offset wheel isnt causing nearly as much stress on the bearings as a car that sees track use. [quote]
this is my thoughts on the matter EXACTLY.
I DON'T have aggressive wheels, hell I run painted stockers for now and steelies in the winter. I DO have 225 width bridgestone RE-01R's and even with the racing (auto-x) I've done, my rear wheel bearings are just now in need of replacing. I have no idea if the previous owner ever did them, I highly doubt it though based on what I've seen maintenance wise so far. Either way, I've gotten 50,000 miles out of my rears with alot of driving with high grip/high load.
I think your driving style and the amount of flogging you do to your car is WAAAAAAY more of a deciding factor in how long your wheel bearings last than how low offset/wide your wheels are.
kaptainkevlar is offline   Reply With Quote
Old 07-28-2009, 07:51 PM   #6
beedee
Member#: 124727
i plan on doing a canyon cruise once or twice a month. other than that, just your average so. cal daily driving.
Old 07-28-2009, 10:38 PM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I think the ill effects a too low offset wheel has on handling should be more of a concern. But when it's all about looks, I guess it doesn't matter.
Old 07-29-2009, 12:18 AM   #8
SomeoneWhoIsntMe
Member#: 160814
2002 WRX Wagon
scrub radius matters that much?
SomeoneWhoIsntMe is offline   Reply With Quote
Old 07-29-2009, 12:51 AM   #9
STi-MAN
Member#: 70252
05 STI
blue
It really depends... when running alot of camber the ill effects of the scrub radius issue become less of a problem.
STi-MAN is offline   Reply With Quote
Old 07-29-2009, 01:37 AM   #10
beedee
Member#: 124727
so would 17x9 +38 would be 'safer' than 17x9 +30?
Old 07-29-2009, 01:41 AM   #11
STi-MAN
Member#: 70252
05 STI
blue
^not only 'safer'. but easier to fit. you prob wont have a concaved looks with most rims with +38 so might want to do some research.
Old 07-29-2009, 03:43 AM   #12
beedee
Member#: 124727
thanks STi-Man. i will look at both versions of the wheel to see if they both are concave.
Old 07-29-2009, 04:04 AM   #13
RonJitsu
Member#: 132301
07 WRX Limited 6MT
20G - SWP - SOLD
STI's and WRX's have different wheel bearings. Us WRX guys have to worry a little more about which wheels we are running, as our wheel bearings are not as durable as the STI's.
RonJitsu is offline   Reply With Quote
Old 08-03-2009, 06:22 PM   #14
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
u think 17x9 on the 04 STi hubs for AutoX is too much?
Dirty25RS is offline   Reply With Quote
Old 08-03-2009, 06:36 PM   #15
Crawdads
Member#: 30907
SWP GDB-G
When I ran ET38 17x9s and 255s/275 R-comps years ago on my WRX (same hubs as your 04 STi) I had to change front wheel bearings twice a year.
Lots of heat and load don't help the situation, its not the 'fault' of the offset, but its not exactly helping either.
If you are tracking the car, wheel bearings should be in the budget up there with pads and rotors and everything else.
Crawdads is offline   Reply With Quote
Old 08-03-2009, 08:27 PM   #16
nhat
Member#: 140163
03 STi
hellaflunctional
i autox'd on 17x9 +39 with 255/40/17 re01rs this year as well as daily driving on the same setup with no issues yet.
crawdads - did you think about switching to 5x114.3 after replacing the front bearings twice?
Old 08-03-2009, 09:31 PM   #17
Crawdads
Member#: 30907
SWP GDB-G
Yes, I did think about it.
Then I did the sensible thing and replaced the WRX with an STi.
Old 08-04-2009, 07:07 PM   #18
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
I agree with you, but I'm sure the heat and load, like you said, were the real issue with your bearings going out. I would imagine that you also replaced them proactively, not because they failed.
Louie is offline   Reply With Quote
Old 08-04-2009, 07:16 PM   #19
mowgli29
Member#: 203438
I just got my bugeye back in Feb, and I've been on 17x9 +38 for a couple months (7 or 8k miles) now. Currently running 255/40-17 T1R and will be sticking with the same size tires when I get new ones in a couple weeks... Good to know you've had no issues
Crawdads, if I'm NOT tracking the car, just DD and some spirited driving...I would imagine I could go quite a bit longer without needing bearing replacements...would you agree?
mowgli29 is offline   Reply With Quote
Symptom of wheel bearing going bad? txl146 Service & Maintenance 10 04-08-2005 12:56 AM
('93-'01) Was there ever some kind of wheel bearing recall? Siper2 Impreza Forum 11 10-03-2003 05:44 PM
Signs of wheel bearing going bad? DDMan Brakes, Steering & Suspension 7 03-22-2003 01:29 PM
Signs of wheel bearing failure??? GTOWNR Legacy Forum 4 02-27-2002 12:51 PM
Warning signs of wheel bearing failure? cakagan Technical Forum Archive 10 09-13-2000 10:53 AM
