Notices
Old 07-28-2009, 06:03 PM   #1
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
Default cannot figure out this exh rattle for the life of me!
so i have had this annoying ass rattle since last october, and i've systematically narrowed it down to what it's NOT. it appears with gas, without gas (when revving down, etc), but mostly when I let off the gas, mostly at low-mid RPMs, and sometimes it goes away, sometimes it's super prevalent. it sounds like it's from the front end of the car but i can't pinpoint the source. here are NOT the causes:
1. downpipe (just replaced helix catted->invidia v4 thinking my cat was dying)
2. turbo (went from TD-04 to VF39 with same rattle)
3. engine (short block has been replaced by subaru b/c of unrelated issue, rattle still there)
4. most leaks (have replaced DPs, checked seals, DP-midpipe gasket replaced, etc)
5. DP mount is sturdy, nothing on the exhaust system touches the chassis
further investigation shows i can make it continuously rattle around 3k rpm (but it is not limited to that range), and it seems to be coming from somewhere around the intake manifold, or the intercooler, or below, but i can't be sure of that.
PROBLEM FIXED! the header connecting brackets were loose.
here is the video:
anyone have any insights? i placed the camera near the O2 sensor because that's one of my next suspicions, but i'm not really sure.
EDIT: here are specs on my car
2.0L (2004 wrx)
vf39, pinks, jdm sti tmic
77k miles
new short block, 4k miles
gruppe-s v1 header
helix UP
invidia v4 catted DP
HKS Carbon Ti catback
dLo R6 is offline   Reply With Quote
Old 07-28-2009, 06:50 PM   #2
MENU
Member#: 208002
2004 WRX
HTA68 EWG FMIC
i get a rattle at 3K rpm, but i just brush it off as a heat shield or somthin exhaust related. I came from a honda so im used to rattles
MENU is offline   Reply With Quote
Old 07-28-2009, 06:50 PM   #3
corzy666
Member#: 177840
2000 swapped RS
White 330whp
Is it rubbing any of your heatshields???(check to see if there are any holes in the shields)
Also check by your rear diff...my exhaust is pretty close to mine.
corzy666 is offline   Reply With Quote
Old 07-28-2009, 06:55 PM   #4
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
no heatshields that i know of to rub on..
like i said, none of the piping is contacting the car (or close to it) =\
Old 07-28-2009, 11:16 PM   #5
Haelan
Member#: 151045
2013 Subaru STI
CBP
Take a rubber mallet and go down the entire length of the exhaust with it. If there's something rattling inside you'll find it that way.
Another common rattle is downpipe's transmission mount being loose.
Haelan is offline   Reply With Quote
Old 07-29-2009, 02:47 PM   #6
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
found nothing in the piping, and mount is sturdy )=
Old 07-29-2009, 06:24 PM   #7
dLo R6
Member#: 108719
2004 VF39'd WRB WRX
2003 Honda CBR600RR
i'm retarded. the connecting brackets on my gruppe-S header (between the two sections for flex) were both loose. smacked the header with my hand while changing the oil this morning and heard the telltale sound. tightened it and NO MORE RATTLE! =D
('93-'01) Fog Harness cannot be found for the life of me minhha2006 Impreza Forum 4 07-07-2008 07:32 AM
I can't for the life of me find this song! OT help me ProjectL Off-Topic 8 10-23-2007 08:07 AM
I can't remember this car from Top Gear for the life of me... HamFist Off-Topic 8 06-08-2007 08:19 PM
can't locate the IAC valve for the life of me... discounteggroll Service & Maintenance 1 06-08-2006 08:15 PM
I cannot decide for the life of me Superbirdy Tire & Wheel 9 12-06-2005 02:42 PM
