Closed Thread
Old 07-28-2009, 07:23 PM   #1
tehhali
Member#: 155142
1996 Legacy
Granola Edition
Default Turn signal fuse blowing out repetitively
The car is a 1996 Legacy Outback:
So after replacing my transmission, something is causing my turn signal fuse to blow out every time it is replaced. I found what appeared to be a broken-off ground cable leading from the top of the engine bay to nowhere, figured it was a transmission ground, so I replaced the end of it with a new O-crimp connector and bolted it to the transmission. However, the circuit is still bad. A small puff of smoke rises from the area around the starter when the switch is thrown with a good fuse put in. Looks like it's coming from the large cable that bolts to one of the starter bolts and leads directly to the negative battery terminal. Has anybody had this problem? I'm not sure where to go at this point. Electrical problems aren't my thing.
CN's:
- Just replaced transmission by myself
- Car starts, runs, drives just fine
- Turns signals do not work, fuse keeps blowing.
- Hazard lights work perfectly, it can be determined that it the problem is not with the blinkers or the bulbs themselves
- When the fuse is replaced, the power is turned on, and the turn signal lever is thrown, a small puff of smoke comes from the area of the starter solenoid, along with a brief "burning wires" smell
- Found a small gauge, approximately 1' long ground cable leading from the engine bay next to the pitch stop, the other end was broken off
- Replaced opposite end with a "O" crimp connector, used to ground the transmission
tehhali is offline
Old 07-29-2009, 11:14 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Unless you are absolutely positive that the wire you put a ring terminal on is a ground wire I suggest you try removing the wire from ground and isolate it to see if that clears the trouble. If that doesn't make a difference it would interesting to know if the short occurs when the lever is moved to either the right or left side; or both sides. If the problem occurs to both sides then I would check the turn signal switch itself to see if something is wrong there.
Cougar4 is offline
Old 01-18-2013, 03:55 PM   #3
10MTN-bugeye
Member#: 288093
2002 Bugeye
PSM and parking lot scars
Tehhali,
I just swapped my 5speed for a 6speed transmission. After searching, I found your 2009 thread, because your car's symptoms were similar. I'm having a rapid blinker problem and also found my small ground is broken. What did you do to resolve your blinker issue? If you repaired the ground did you route it from the firewall pitchstop mount to the transmission bell house pitchstop mount? Thanks to anyone with the time to post a useful response.
10MTN-bugeye is offline
Old 01-18-2013, 11:00 PM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
You've got a dead short, most likely a pinched wire or the one you hooked up..
Aaron'z 2.5RS is offline
Old 01-19-2013, 07:50 AM   #5
Cougar4
Member#: 53443
Winestone
This thread needs to be closed. It is ancient history.
Cougar4 is offline
Old 01-19-2013, 11:10 AM   #6
10MTN-bugeye
Member#: 288093
2002 Bugeye
Originally Posted by 10MTN-bugeye View Post
Thanks to anyone with... a useful response.
Old 05-28-2014, 10:36 AM   #7
Don Sutherland
Member#: 74940
Default Turn Signal Fuse Blows, No Electric Windows
On my 2005 Impreza 2.5 RS, all 4 electric windows suddenly stopped working, then a few minutes later I noticed that I had no turn signals. There was no fuse for the electric windows, but the turn signal fuse was blown and would blow as soon as soon as the ignition was turned on. The hazard flashers worked normally. My dealer found that when the ignition interlock had been installed by the dealer, as required for insurance purposes when I bought the car new, the wires had just been twisted together and taped (no solder) and had come apart. This mess had been a ticking time bomb for over 9 years. The dealer apologized and said they didn't do things like that any more, but it still cost me $300.
Don Sutherland is offline
Old 05-28-2014, 09:05 PM   #8
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
make you own thread.
aerosaaber is offline
Closed Thread
Turn Signal Fuse!!! Dunkinuts Electrical & Lighting 3 01-16-2010 10:00 PM
Fuses blowing out after swap rs4buddy Subaru Conversions 2 08-18-2009 09:51 PM
Turn Signal Fuse Blown!! kintalle88 Electrical & Lighting 2 07-13-2005 07:44 AM
Turn signal fuse blowing AWDspider Electrical & Lighting 3 04-02-2005 07:19 PM
right front turn signal fuse? soob2k General Forum Archive 1 03-10-2001 02:14 PM
