Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 07-28-2009, 08:37 PM   #1
Ti Pit
Member#: 146009
2005 Baja Turbo
Default Would this wheel size fit a turbo Baja?
Alright here's the deal.. I`m really a noob when it comes to wheels. I`ve tried reading topics on Nasioc that talk about offset and sizes however I just can grab the concept and I get very confused with the + and the - and then the tire ratio.
I have a 2005 Turbo Baja.
Would this fit?
18X8
Offset +48mm
On the same note, the website (tirerack) recommends 235/45/18 .. does this sound right?
Finally does anyone know how much the stock wheels weigh? These aftermarket rims weigh in at 24lbs, I wonder if this is an upgrade or downgrade weight wise.
Thanks a lot for your help!
Ti Pit is offline   Reply With Quote
Old 07-31-2009, 11:01 PM   #2
sangwooTwrx-wgn
Member#: 210713
2007 wrx-wgn
wrb
turbo baja :: nice
+1 fitment you up rim size 1 inch
+2 means you up rim size 2 inches ** your question is about a +2 because your stock OEM rims are 16" right?
16" ---> 18" = +2 fitment
the tire size 235/45zr18 sounds about right. what you could do is look up the specs and see the diameter of the tires . you might want a taller tire? a 235/50r18 but that is a weird size.. a 245/45zr18 might be too wide to be a winter tire..
the tire width, 235mm, is about 9.25" wide so the rims being 8" it should be a good fit.
and i think youll have more total weight with the 18" fitment (meaning less handling from reading the forums here) most metal alloys weigh more then synthetic rubber and synthetic cord . which what the sidewall is mostly made of.
idunno about rims much but im figuring if you need a spacer because of non stock offset i wouldnt buy it .. jus another part to lose/crack/buy/etc know what i mean?
sangwooTwrx-wgn is offline   Reply With Quote
how would this wheel look? lowrider89 Tire & Wheel 7 10-25-2008 11:45 PM
Will other Subaru wheels fit an 05' Baja Turbo? WYSubaru Baja Forum 2 03-18-2008 07:00 PM
Are 5mm spacers enough to clear this wheel size wrx-sleeper Tire & Wheel 4 02-01-2007 10:44 AM
Would this wheel be ok on MY02 WRX Starscream Tire & Wheel 10 01-13-2005 10:59 AM
help! will this size fit OEM wrx wheels??? esper Tire & Wheel 2 10-28-2004 03:27 PM
Message Board Statistics All times are GMT -4. The time now is 07:52 AM.
