07-29-2009, 06:13 AM | #1 |
Member#: 172548
SWIC
Vehicle:2010 WRX STi WR Blue |
A/C Help
My A/C belt squeals every time it's engaged and there is a slight film that looks similar to brake dust around the compressor. I'm pretty sure it is the clutch in side the A/C pulley. My question is, would it be cheaper and easier to just replace the pulley or should I just replace the entire compressor? Keep in mind that I have about 80k mi and the A/C still blows cold. Thanks for the help guys.
07-29-2009, 10:15 AM | #2 |
Member#: 74321
Vehicle:2004 wrx wag black UTEC stg 4 |
as far as I know the only fix for this is to replace the compressor. if you can find a clutch assy. that would work, but it's not sold that way.
07-29-2009, 11:18 AM | #3 |
Member#: 172548
SWIC
I'll have to double check but I thought I saw a part number for it sold separately.
07-29-2009, 04:54 PM | #4 |
Member#: 17252
Vehicle:'06 WX8 59E |
The dust is just rust that comes off from the clutch plate and pulley surfaces. It's two steel parts pulled together by the magnetic coil. Is the belt tight?
07-29-2009, 05:07 PM | #5 |
Member#: 201184
International
Vehicle:2001 WRX |
It would be cheaper to replace just the clutch/coil/pulley assembley. That is if you can find a clutch removal tool for your specific compressor. It would probably be easier just to replace the compressor, which would come fully assembled, with the new clutch/coil/pulley assembley.
I tried "just" replacing the clutch assembly on my Cavalier, but my clutch removal tool broke. Instead of continuing to mess around with it, I just ordered a new compressor. I wish I would have gotten the new compressor in the first place. Remember to have the system discharged before you start taking it apart. You should also have it flushed before you put on the new compressor (if thats what you do). Also, when I did this on my Cavalier I had to replace the accumulator and orifice tube; not sure if that is standard for most vehicles, so you should definitely check into it. |
07-29-2009, 08:48 PM | #6 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Black dust is probably the belt slipping. You may need to either tighten the belt or replace it. |
07-31-2009, 07:11 PM | #7 |
Member#: 172548
SWIC
I noticed my belts are starting to look old, I'll try and change them to see if that helps, thanks.
08-01-2009, 09:15 PM | #8 |
Member#: 172548
SWIC
New belts were just the ticket! Thanks for the help!
08-02-2009, 09:46 AM | #9 |
Member#: 30669
08-03-2009, 03:55 PM | #10 |
Member#: 33284
Vehicle:2002 WRX silver |
I just wd-40'd the hell out of it, cause i had the same problem, and now no squeal or anything, smooth.
08-03-2009, 07:41 PM | #11 |
Member#: 30669
Help! | bluesbrother | Mid Atlantic Impreza Club -- MAIC | 8 | 06-08-2010 12:10 AM |
help!!! flashing cel and no one can help | tommy 02wrx | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 06-05-2010 07:26 PM |
Help. o2 sensor | subizzo02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 06-04-2010 07:03 PM |
anyone have a pioneer avic u310bt need some help | cosanostra | Car Audio, Video & Security | 5 | 06-04-2010 12:20 PM |
need help with a/c compressor replacement | sen7inel | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 0 | 06-04-2010 08:53 AM |
