Old 07-29-2009, 02:37 PM   #1
ASF
Member#: 218500
1997 OBS
Green
Default Will a silicone turbo inlet fit under an EJ25D intake manifold?
Will an EJ205 style silicone turbo inlet (like Gimmick or Perrin etc) fit under an EJ25D intake manifold if one relocated the PS pump res.?
ASF is offline   Reply With Quote
Old 07-29-2009, 05:20 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
You might have to do something with the fuel lines also.
Old 07-29-2009, 05:47 PM   #3
ASF
Member#: 218500
1997 OBS
Green
Addressed with a homemade parallel kit.
Otherwise this is affirmative?
Old 07-29-2009, 06:49 PM   #4
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
I dont think its much diff than the ej251 setup minus the air assit on the passanger side and vacum for the FPR.
Don't think there is much room there to run anything under the manifold and you would have to redo your fuel lines.
Not sure what other manifolds fit on the 98's.....maybe a older JDM sti mani?
freeride is offline   Reply With Quote
Old 07-29-2009, 07:45 PM   #5
turbo01gc8
Member#: 217973
2001 turbo impreza L
acadia green
doesn't the clearance have to do with the extra height from the TGV's?
turbo01gc8 is offline   Reply With Quote
Old 07-29-2009, 08:35 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
No, the EJ25 n/a manifold is just as tall as the usdm ej20 intake manifold +tgv combo.
Old 07-30-2009, 10:20 AM   #7
ASF
Member#: 218500
1997 OBS
Green
I figured the 25D was the same era of the 20K and the 20K has no TGVs with an under manifold inlet.
I found one someone else did.
http://forums.nasioc.com/forums/show...2&postcount=55
Old 07-31-2009, 10:51 AM   #8
master c
Member#: 168226
the problem lies with the coolant crossover pipe being too tall and at the wrong angle
master c is offline   Reply With Quote
Old 07-31-2009, 01:06 PM   #9
ASF
Member#: 218500
1997 OBS
Green
Would this be an issue if one was using a 257 block with a 257 coolant crossover?
Old 07-31-2009, 02:46 PM   #10
master c
Member#: 168226
the 257 setup will work fine
Old 08-01-2009, 12:58 AM   #11
turbo01gc8
Member#: 217973
acadia green
are the intake manifolds interchangeable besides the EGR equipped ones? do some flow better than others?
Old 08-01-2009, 02:40 AM   #12
ASF
Member#: 218500
1997 OBS
Green
I think my EJ20G mani may flow better but I don't want to buy or make a spacer.
Old 09-15-2009, 11:36 PM   #13
ASF
Member#: 218500
1997 OBS
Green
Inlet fits under an EJ20G intake manifold if you use 8mm spacers, an EJ257 crossover tube and a phase II style PS pump. Yay.
Visteon Radiator-Throttle Bodies (EJ20G/EJ25D/etc.)-EJ20G+EJ25D Intake Manifold-ETC! Audioexcels Engine/Power/Exhaust 24 07-22-2010 09:23 AM
Visteon Radiator-Throttle Bodies (EJ20G/EJ25D/etc.)-EJ20G+EJ25D Intake Manifold-ETC! Audioexcels NWIC Private Classifieds 23 07-22-2010 09:22 AM
FS 2006 wrx intake manifold, tgvs, etc, etc. and silicone turbo inlet Keif Engine/Power/Exhaust 0 09-03-2008 05:07 PM
Replacing Factory Turbo Inlet Hose w/o Removing intake manifold wrxnova1 Newbies & FAQs 7 10-09-2006 01:58 PM
Replacing Factory Turbo Inlet Hose w/o Removing intake manifold wrxnova1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-09-2006 01:05 PM
