Old 07-29-2009, 03:41 PM   #1
Ekeenan86
Member#: 155493
1999 Legacy Outback
Default Replacing Head Gasket- What Else?
I have my subaru in the shop right now to have the head gastket replaced, new timing belt and water pump and a new clutch to be put on. Im interested if theres anything else I should get done while it is in there. I was thinking spark plugs as well. Keep in mind Its an Outback with about 205,000 miles on it. Thanks!!
Ekeenan86 is offline   Reply With Quote
Old 07-30-2009, 12:38 AM   #2
Ekeenan86
Member#: 155493
1999 Legacy Outback
bump!
Old 07-30-2009, 08:49 AM   #3
magicstop
Member#: 206853
2004 WRX Wagon
TXS Stage 4
Have 'em check your tensioners and bearings.
magicstop is offline   Reply With Quote
Old 07-30-2009, 10:05 AM   #4
Davenow
Member#: 23676
Timing belt
Tensioner
Water pump
That is the standard list to do with the head gaskets.
Old 07-30-2009, 11:01 AM   #5
ShaneInHisRoom
Member#: 148737
Compression test when everything is said and done.
ShaneInHisRoom is offline   Reply With Quote
Old 07-30-2009, 11:06 AM   #6
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Make sure the heads are checked/milled for warping. A competent shop should already do that though.
trueno16v is offline   Reply With Quote
Old 07-30-2009, 11:32 AM   #7
Ekeenan86
Member#: 155493
1999 Legacy Outback
Yeah they said they would be sending them out to be resurfaced. Do I replace anything with the synchronization?
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
Head Gasket? What else could it be? huckedup16 Legacy Forum 7 06-25-2008 11:41 AM
Head Gasket? What else could it be? (XPosted in Legacy) huckedup16 Normally Aspirated Powertrain 0 06-24-2008 01:32 PM
replacing head gasket... P&P...what else? IllNastyImpreza Built Motor Discussion 3 03-07-2007 07:39 AM
('93-'01) replacing head gaskets GTkrockett Impreza Forum 4 10-07-2001 04:45 PM
