Old 05-01-2002, 08:07 PM   #1
DoinkMobb
Member#: 3787
2008 Gay
Car
Default front left wheel squeaks during left turns, brakes also squeaking
I notice squeaking coming from the front left tire during left hand turns. I usually notice this when driving through my apt. complex with the window open at low speeds. I don't hear anything from the right side but this may be because there is no squeaking or I just can't hear it from the driver's seat. Also, the brakes squeak A LOT when low-medium pressure is applied. When I step on them pretty hard, they're quiet. My brakes suck pretty bad too, there isn't a whole lot of stopping power. When I changed a spare today I looked at the disc and the pad quickly and didn't see anything out of the ordinary. Looked like normal wear and tear to me. Whaddya think, just get it checked out by a mechanic or should I try to figure out the problem myself?
DoinkMobb is offline   Reply With Quote
Old 05-02-2002, 05:02 AM   #2
DBAsteve
Member#: 16839
Sometimes its just build up of dust that causes the squeal or if your pads dont have anti squeal shims. Try blasting the dust out with the hose ( on cold rotors only please ). If that doesn't work get some shims fitted or buy some new pads with anti squeal shims fitted.
Steve
DBAsteve is offline   Reply With Quote
Old 05-02-2002, 03:05 PM   #3
DoinkMobb
Member#: 3787
2008 Gay
Car
Alright, I'll try cleaning off the rotors. Anybody else have some suggestions?
Old 05-02-2002, 03:24 PM   #4
romanom
Member#: 16215
2002 WR WRX wagon
Steve posted the most likely issue.
You mau also need to grease the studs the caliper slides on.
You already checked pads for wear and that is the only other thing I can think of.
romanom is offline   Reply With Quote
Old 05-02-2002, 04:39 PM   #5
I drive a WRX wagon
Member#: 9219
02 IS300 5sp
i had that same exact problem not too long ago. it just ment that i needed to change my brake pads. changed them and the problem went away
I drive a WRX wagon is offline   Reply With Quote
Old 05-02-2002, 08:15 PM   #6
DoinkMobb
Member#: 3787
2008 Gay
Car
Alrighty, maybe I'll just go ahead and buy new brake pads and see if that fixes the problem. What about the squeaking coming from the wheel on left turns? Suggestions?
My front left wheel squeaks bloodlust Newbies & FAQs 9 03-16-2008 08:37 PM
Front Left Wheel Squeaking. Rock in Rotor... (pics) BoardRider Brakes, Steering & Suspension 0 04-03-2006 03:08 PM
*Squeak squeak squeak* from left front while turning - Help? Patrick Olsen Brakes, Steering & Suspension 13 07-22-2002 05:10 PM
High-pitched squeak during upshifting everbruin Warranty Issues & SOA Problems 4 02-13-2002 09:13 PM
Noise from right front during left turns with bumps in road beaster Brakes, Steering & Suspension 9 10-12-2001 11:46 AM
