Old 05-01-2002, 08:23 PM   #1
walnats
Member#: 17329
1997 Impreza/Outback
White/gray
Question Between shift rattle
When ever I shift I hear a rattle, sounds like one of the exhuast shields? But I can't be sure. It also happens if I rev up the engine then quickly let off the gas. Anyone have a clue?
-Walter
walnats is offline   Reply With Quote
Old 05-01-2002, 10:08 PM   #2
booger
Member#: 6446
99 Impreza 2.5 RS
got the same thing...
kinda sounds like a rusty BOV (at least what id think a rusty BOV would sound like)
no idea whats causing it either
booger is offline   Reply With Quote
Old 05-02-2002, 11:48 PM   #3
walnats
Member#: 17329
White/gray
BOV?
Old 05-03-2002, 01:37 AM   #4
Slack
Member#: 17548
BOV = Blow off valve.
Slack is offline   Reply With Quote
Old 05-03-2002, 11:31 PM   #5
walnats
Member#: 17329
White/gray
If it is the BOV what can I do to fix it? Also is there a way to make certain that it is the BOV?
Thanks appreciate your help!
-Walter
Old 05-03-2002, 11:36 PM   #6
walnats
Member#: 17329
White/gray
Also, does a N/A OBS have a BOV? I thought it was just on turbo's?
-Walter
Old 05-04-2002, 08:16 AM   #7
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
They are. Try a heat shield on the exhaust somewhere. With the car cold, and off, get under it and start to bang on the heat shields until you find the one that is rattling.
Stealthbmbr is offline   Reply With Quote
Why is my 6sp Kartboy short shift rattling? Simes Transmission (AT/MT) & Driveline 18 08-12-2009 12:09 PM
Gear shift Rattle bfodle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-21-2005 06:58 PM
Strange rattling sound in between shifts- advice please! chill105 Transmission (AT/MT) & Driveline 3 02-20-2004 11:37 AM
mbc installed, now have loud noise between shifts (off throttle) fogeyes Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-08-2001 08:11 PM
WRX + aftermarket BOV = prevent surge between shifts? djerickd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-26-2001 01:29 PM
