Old 07-30-2009, 02:34 AM   #1
robinbrd311
Member#: 212207
2004 Impreza WRX
Java Black Pearl
Default Advice Needed for a recent problem with turbo
A few months ago I had to get my maf sensor retuned be cause there was a System Too Lean engine light and the car would knock around 4-6k rpm because the MAF sensor was not working correctly. The Dent Sports Garage in MA simply retuned the sensor and it worked properly up til now.
I drove my car to NY, a 3 hour drive, and it worked fine. On the way back I was accelerating quickly after a toll and the car lagged in each gear around the higher rpms. Every time after that when I had to accelerate to highway speed from a stop the same thing would happen but worse. When I got home the car was in the condition where if I started from first and floored it it would go to a bout 4 or 5k rpm then either stop there or knock and lag a lot and the engine light would flash until I shifted, and the same thing would happen in 2nd gear. (Didn't get to 3rd gear on my street)
I am guessing it is a problem with the MAF sensor again but before I go in and pay for them to work on it I was wondering if anyone knew anything about this.
2004 WRX, Cobb short ram intake, turbo XS front mount intercooler, one step colder spark plugs, tuned at dent sport 15psi boost
robinbrd311 is offline   Reply With Quote
Old 07-30-2009, 05:32 AM   #2
coldturbo
Member#: 168900
2002 Impreza WRX
Vf-39 Grp.N luv
A few things wrong here.
If you had a defective MAF sensor and knew it that, it should have been the end of your tuning day. You will never get that engine right without the correct MAF readings.
Second if your car is not running well at low speed, beating it to high speeds is exactly the wrong thing to do and only make it worse. Do not drive the car.
What boost did you see when you got the 5k? I am guessing you have a boost leak somewhere with the FMIC piping.
Get a new MAF and have the car towed to a tuner.
Do you have a FMIC on the stock turbo? Why only 16 lbs?
Lastly you should return to stock heat range plugs.
coldturbo is offline   Reply With Quote
Advice Needed for a recent problem with turbo robinbrd311 Service & Maintenance 3 08-02-2009 01:52 AM
Advice Needed for a recent problem with turbo robinbrd311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-30-2009 05:28 PM
Advice Needed for a recent problem with turbo robinbrd311 New England Impreza Club Forum -- NESIC 4 07-30-2009 01:38 PM
Advice Needed for a recent problem with turbo robinbrd311 Other Engine Management 1 07-30-2009 01:02 PM
Recent problem with my rex. injustice Texas Impreza Club Forum -- TXIC 6 09-25-2007 08:48 PM
