Old 07-30-2009, 02:36 AM   #1
robinbrd311
Member#: 212207
2004 Impreza WRX
Java Black Pearl
Default Advice Needed for a recent problem with turbo
A few months ago I had to get my maf sensor retuned be cause there was a System Too Lean engine light and the car would knock around 4-6k rpm because the MAF sensor was not working correctly. The Dent Sports Garage in MA simply retuned the sensor and it worked properly up til now.
I drove my car to NY, a 3 hour drive, and it worked fine. On the way back I was accelerating quickly after a toll and the car lagged in each gear around the higher rpms. Every time after that when I had to accelerate to highway speed from a stop the same thing would happen but worse. When I got home the car was in the condition where if I started from first and floored it it would go to a bout 4 or 5k rpm then either stop there or knock and lag a lot and the engine light would flash until I shifted, and the same thing would happen in 2nd gear. (Didn't get to 3rd gear on my street)
I am guessing it is a problem with the MAF sensor again but before I go in and pay for them to work on it I was wondering if anyone knew anything about this.
2004 WRX, Cobb short ram intake, turbo XS front mount intercooler, one step colder spark plugs, tuned at dent sport 15psi boost
robinbrd311 is offline   Reply With Quote
Old 07-31-2009, 08:18 PM   #2
WcW
Member#: 209963
could be a vac. leak was the cause of the code and the leak has gotten worse. could be a thousand things..
WcW is offline   Reply With Quote
Old 07-31-2009, 08:50 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Originally Posted by robinbrd311 View Post
I am guessing
exactly - pull the trouble code(s) and go from there
UkNuck is offline   Reply With Quote
Old 08-02-2009, 01:52 AM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
yeah you probably hava big vacuum leak or a bad MAF, my guess would be around the turbo inlet area. Do you know what your fuel trims are at idle?
Advice Needed for a recent problem with turbo robinbrd311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-30-2009 05:28 PM
Advice Needed for a recent problem with turbo robinbrd311 New England Impreza Club Forum -- NESIC 4 07-30-2009 01:38 PM
Advice Needed for a recent problem with turbo robinbrd311 Other Engine Management 1 07-30-2009 01:02 PM
Advice Needed for a recent problem with turbo robinbrd311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-30-2009 05:32 AM
Recent problem with my rex. injustice Texas Impreza Club Forum -- TXIC 6 09-25-2007 08:48 PM
