Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-30-2009, 01:37 AM   #1
robinbrd311
Member#: 212207
2004 Impreza WRX
Java Black Pearl
Default Advice Needed for a recent problem with turbo
A few months ago I had to get my maf sensor retuned be cause there was a System Too Lean engine light and the car would knock around 4-6k rpm because the MAF sensor was not working correctly. The Dent Sports Garage in MA simply retuned the sensor and it worked properly up til now.
I drove my car to NY, a 3 hour drive, and it worked fine. On the way back I was accelerating quickly after a toll and the car lagged in each gear around the higher rpms. Every time after that when I had to accelerate to highway speed from a stop the same thing would happen but worse. When I got home the car was in the condition where if I started from first and floored it it would go to a bout 4 or 5k rpm then either stop there or knock and lag a lot and the engine light would flash until I shifted, and the same thing would happen in 2nd gear. (Didn't get to 3rd gear on my street)
I am guessing it is a problem with the MAF sensor again but before I go in and pay for them to work on it I was wondering if anyone knew anything about this.
2004 WRX, Cobb short ram intake, turbo XS front mount intercooler, one step colder spark plugs, tuned at dent sport 15psi boost
robinbrd311 is offline   Reply With Quote
Old 07-30-2009, 03:09 PM   #2
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
Call your tuner.. call the shop that replaced the sensor and see if they warranty their work.. How long ago did the sensor get replaced? Also.. I know you listed your car and mods, but fill out your profile anyway for next time.
AlxSti is offline   Reply With Quote
Old 07-30-2009, 04:28 PM   #3
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Try cleaning your MAF first, CRC sells a MAF cleaner at most auto parts stores for a few dollars.
Advice Needed for a recent problem with turbo robinbrd311 Service & Maintenance 3 08-02-2009 12:52 AM
Advice Needed for a recent problem with turbo robinbrd311 New England Impreza Club Forum -- NESIC 4 07-30-2009 12:38 PM
Advice Needed for a recent problem with turbo robinbrd311 Other Engine Management 1 07-30-2009 12:02 PM
Advice Needed for a recent problem with turbo robinbrd311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-30-2009 04:32 AM
Recent problem with my rex. injustice Texas Impreza Club Forum -- TXIC 6 09-25-2007 07:48 PM
