Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 07-30-2009, 01:38 AM   #1
robinbrd311
Member#: 212207
2004 Impreza WRX
Java Black Pearl
Default Advice Needed for a recent problem with turbo
A few months ago I had to get my maf sensor retuned be cause there was a System Too Lean engine light and the car would knock around 4-6k rpm because the MAF sensor was not working correctly. The Dent Sports Garage in MA simply retuned the sensor and it worked properly up til now.
I drove my car to NY, a 3 hour drive, and it worked fine. On the way back I was accelerating quickly after a toll and the car lagged in each gear around the higher rpms. Every time after that when I had to accelerate to highway speed from a stop the same thing would happen but worse. When I got home the car was in the condition where if I started from first and floored it it would go to a bout 4 or 5k rpm then either stop there or knock and lag a lot and the engine light would flash until I shifted, and the same thing would happen in 2nd gear. (Didn't get to 3rd gear on my street)
I am guessing it is a problem with the MAF sensor again but before I go in and pay for them to work on it I was wondering if anyone knew anything about this.
2004 WRX, Cobb short ram intake, turbo XS front mount intercooler, one step colder spark plugs, tuned at dent sport 15psi boost
robinbrd311 is offline   Reply With Quote
Old 07-30-2009, 02:09 AM   #2
burtonrider
Member#: 145644
02 rwd impreza wrx
is your check engine light on cause mine did the same thing when my intake got wet the code was for maf high input
burtonrider is offline   Reply With Quote
Old 07-30-2009, 10:36 AM   #3
shampy2k
Member#: 202848
05 Sti
silver with silver wheels
could it be the one step colder plugs? I thought those where for cars with 100 plus hp over stock.
shampy2k is offline   Reply With Quote
Old 07-30-2009, 11:04 AM   #4
mattminer
Member#: 90642
WKD Everything
defintely sounds like a dirty or broken maf, maybe improperly scaled but that souns kind of extreme for a maf thats only scaled a little wrong.
M@
mattminer is offline   Reply With Quote
Old 07-30-2009, 12:38 PM   #5
MYfirst00
Member#: 22928
2015 Legacy Limited
Lapis Blue
Get a replacement MAF. If you're getting knock, it's because the engine is trying to compensate for faulty MAF readings. I just went through this. P0171. Bren read my live readings and my air was all out of whack at all load levels, and causing knock. Swapped the MAF, completely normal. No issues since. There were no MAF codes, which threw me off the trail for about a month.
MYfirst00 is offline   Reply With Quote
Advice Needed for a recent problem with turbo robinbrd311 Service & Maintenance 3 08-02-2009 12:52 AM
Advice Needed for a recent problem with turbo robinbrd311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-30-2009 04:28 PM
Advice Needed for a recent problem with turbo robinbrd311 Other Engine Management 1 07-30-2009 12:02 PM
Advice Needed for a recent problem with turbo robinbrd311 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-30-2009 04:32 AM
Recent problem with my rex. injustice Texas Impreza Club Forum -- TXIC 6 09-25-2007 07:48 PM
