Old 07-30-2009, 10:04 AM   #1
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Default So a dead spot in the center of my steering has developed...
My steering has recently developed about a 5-10 degree dead spot in the middle of my steering(feel like im driving a car made in the 80's). My intial thoughts are bad tie rod ends? Car is an 02 wrx with 70k on the clock, 30k of the miles on coilovers. Are tie rod ends supposed to go bad this quickly? Maybe a loose steering rack bracket? Bad steering rack?
My top hats are torn some as well, they are getting replaced this weekend...but i didnt/dont think that was the cause. Ive been wrong before though.
Any help appretiated guys.
Oh, and should i hold off on installing the new tophats and getting my alignment until i fix the deadspot steering issue? Or can i go ahead and do the tophats and alignment and fix the dead spot later?
Swine is offline   Reply With Quote
Old 07-30-2009, 10:07 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Steering rack bushings?
We had a high milage car come in with the same complaint. When we looked the stock rack bushings were no longer there.
Old 07-30-2009, 10:35 AM   #3
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
If its a bad rod end or ball joint you can pretty easily grab and wiggle it to find out. If its not those you've pretty much limited it down to the rack bushings or the steering column/shaft.
Scooby921 is offline   Reply With Quote
Old 07-30-2009, 12:41 PM   #4
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
I had a similar problem develop last year. Turned out that the pinch bolt holding the steering column to the rack had gotten a bit loose. Tightened that up and it fixed the problem.
_Jeff
Portly is offline   Reply With Quote
Old 07-30-2009, 04:05 PM   #5
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Sounds like steering rack bushings wore out.
Maybe the bushing in the steering linkage is worn out.
Or possibly you inner tie rods are worn out.
Ian,
rexworx is offline   Reply With Quote
Old 08-02-2009, 07:18 PM   #6
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Passenger side steering rack bushing managed to get cut in half and was making its way out either side of the bracket. So far this seems to be the culprit.
Old 08-31-2009, 01:22 PM   #7
Swine
Member#: 16197
05 LGT 18G-beater
12' Coyote Stang M6
Replaced the bushings and shes drives normal again. Thanks guys
Old 08-31-2009, 03:02 PM   #8
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
Another blazing success story brought to you by....
blernin41 is offline   Reply With Quote
Did you see a sign in the front of my house that said dead ****** storage? hitman912 Off-Topic 65 12-26-2006 12:13 AM
So there is this dead car on the side of my house. alacrity024 Off-Topic 77 02-08-2006 03:37 PM
So there is this dead cat on the side of my house. mAdatee Off-Topic 40 02-08-2006 01:47 PM
So which city is really the center of the US MidnightSti05 Off-Topic 124 07-08-2005 10:35 PM
So I found myself sitting in the trunk of my roommates Jetta.... 2pt5RS Off-Topic 20 04-18-2005 02:06 AM
