Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-30-2009, 12:56 PM   #1
PSUbaru_guy
Member#: 181879
2008 STI
Default Using API SL oil when manual calls for API SM
Hey guys,
So I just changed my oil yesterday and I wasn't paying close attention when I bought the oil. I picked up 5 qts of Royal Purple 5W-30, it's tested to API SL standards. When I was changing the oil, I checked the manual and it said to use API SM oil although SL is ok if you live in/near the desert and experience high temperatures. I live in the desert in WA and it's going to be really hot here for the next 2 months or so. Does anyone think that I will have problems with the SL oil I used? I don't know anything about the differences between the standards testing but the viscosity/weight are the same. Any help is greatly appreciated.
Oh, I spoke with the parts dept at my local dealership and they said that I shouldn't have any problems but I just wanted to ask the NASIOC experts and get your opinions.
Thanks!
PSUbaru_guy is offline   Reply With Quote
Old 07-31-2009, 08:43 AM   #2
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Shouldn't be a problem at all, although I'd recommend keeping a close eye on the oil level as RP 5W-30 is a pretty 'thin' 30-weight oil which has been known to shear down to a 20-grade oil over a fairly short period of time. Best to watch the oil level to make sure your engine isn't consuming the oil.
AndyH is offline   Reply With Quote
Old 07-31-2009, 09:39 AM   #3
PSUbaru_guy
Member#: 181879
2008 STI
ok thanks Andy! I'll keep an eye on the level.
Old 07-31-2009, 12:02 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
you couldnt PAY ME to put that RP garbage in my engine
no ****ing way
bad idea....great way to a spun bearing
Old 07-31-2009, 12:50 PM   #5
PDLTURBO
Member#: 73129
2004 WRX #50ESP
San Remo Red
I was running RP 5w30 for the 3 oil changes and I now have a spun rod bearing going to be researching oils to see what is the best. I know motul is good but very expensive.
The bearings are so small on the boxer and I won't be using RP ever again!
PDLTURBO is offline   Reply With Quote
Old 07-31-2009, 06:12 PM   #6
PSUbaru_guy
Member#: 181879
2008 STI
Oh really? damn, now I want to change the oil...
Old 07-31-2009, 09:36 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
It's in appendix G of this document:
http://new.api.org/certifications/en...forprint-2.pdf
keep in mind that they are just a sequence of tests - in other words, just because an oil is listed as SL doesn't mean it wouldn't meet the requirements for SM. That being said, RP does shear down pretty quickly.
Old 08-02-2009, 11:34 AM   #8
bluesubie
Member#: 767
04 FXT
When you're down 1-2 quarts in 1,000 miles, just throw in some RP 20W50. You should have a decent 40 grade then.
-Dennis
bluesubie is online now   Reply With Quote
Old 08-06-2009, 09:41 AM   #9
djosbun
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
-Dennis
Mixing 5W-30 with 20W-50 does not give you 40-grade oil. All is does is give you a mixture of of the two different weight oils.
djosbun is offline   Reply With Quote
Old 08-07-2009, 06:38 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
you need to stop posting as the above shows you need to listen more than post
and you are wrong
Old 08-07-2009, 10:31 AM   #11
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Right or wrong, major oil companies will tell you the same thing. So, it's not unlikely that the person was listening to someone from a company that actually manufactures motor oil.
Aside from that, neither of you are necessarily wrong, nor are either of you necessarily right. All multi-grade motor oils are made from multiple base oil grades blended together. And, any two examples of a given grade are not necessarily made with the same base stock blend. So when you combine 2 very different grades together, you don't know for sure what the result will be, exactly. Combine that with the fact that it is far more common than not that a 5W30 and a 20W50 (even from the same company) will have extremely different additive systems, and it's really a crap shoot. Shouldn't normally cause harm, but it's much more complex and frankly different than simply averaging the numbers, even if you use a blending calculator. The 100C viscosity is reasonably likely to come out as a 40-grade somewhere, but the rest you're guessing at. Even the 40-grade part could be a decent one or a poor one depending upon the components of the 2 you mixed.
bulwnkl is offline   Reply With Quote
FS : Parting my car out W0R7Xsubi Tri-State Area Private Classifieds 251 06-17-2014 01:31 PM
Unable to find API Sevice SL oil. njchen24 General Community 6 11-16-2005 11:12 PM
Ever try to use the "spanish" option when calling customer service? -=C=- Off-Topic 5 06-13-2005 02:24 PM
Last call for the May 15th tranny fluid\motor oil\rear gear oil day!! Dynamispeed Southern California Impreza Club Forum -- SCIC 2 05-12-2004 03:59 PM
My engine eats oil when I use synthetic? poison Service & Maintenance 11 02-10-2004 05:29 PM
