07-30-2009, 03:17 PM | #1 |
Member#: 217248
Vehicle:2009 STI Black |
Fluid capacity question
Hi everyone
I checked in the owners manual and did some searching and I couldn't find an answer but its also possible I overlooked as well. I wanted to know how much fluid (quarts) I would need because I plan on changing them on a vehicle I just purchased (2005 WRX) 1. Brake Fluid 2. Transmission Fluid Thanks in advanced.
07-30-2009, 05:19 PM | #2 |
Member#: 140244
Vehicle:2002 bugeye still rippin' hard |
1. get at least 2 bottles (refering to oem, I think 354ml per bottle)
2. 3.7 quarts for the transmission, 0.8-1 qt for the rear differenatial |
07-30-2009, 06:39 PM | #3 |
Member#: 217248
Ok, thank you very much.
07-30-2009, 08:37 PM | #4 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Which trans? MT or AT??
The AT will need 2 different fluids, one is for the trans and the other is for the front diff. |
07-30-2009, 09:34 PM | #5 |
Member#: 216135
Vehicle:2011 |
Also, the 3.7 quote is for the MT but that is assuming a rebuild and a completely dry gear box. When I did mine, I put in 3.375 qts in and I'm a nudge above the upper dot. I let it drain for about 1.5 hours with the rear tires about 4 inches off the ground so it was very empty.
07-30-2009, 10:42 PM | #6 | |
Member#: 140244
I posted outa my ass by assuming he had a manual trans.... OP if you have automatic, use only subaru ATF if you want to have smooth shifting trans and no issues. |
07-31-2009, 10:07 AM | #7 |
Member#: 217248
I'm sorry I thought I did state that I did have a manual...guess I didn't lol.
yes, manual transmission. Thank you guys. |
07-31-2009, 10:11 AM | #8 |
Member#: 216135
Vehicle:2011 |
Add about 3.1-3.2 qts and then check and do a little and check, little and check. You will NOT put a full 3.7 qts in the gear box....just a heads up.
07-31-2009, 10:15 AM | #9 |
Member#: 217248
sti brake fluid capacity | lukerussell | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 02-10-2004 10:33 PM |
spark plug gap & fluid capacities | jamest46 | Service & Maintenance | 5 | 12-18-2003 06:20 PM |
Minimum Rotor Thickness and Brake Fluid capacity? - MY98 RS | glyphic | Brakes, Steering & Suspension | 2 | 07-19-2002 10:39 PM |
Fluid capacity of clutch | cmaj7 | Transmission (AT/MT) & Driveline | 1 | 07-13-2002 02:24 PM |
Anyone know the full fluid capacity of the RS braking system? | North Ursalia | Brakes, Steering & Suspension | 3 | 02-11-2001 06:46 PM |
