Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Old 07-30-2009, 04:33 PM   #1
crofrog
Member#: 57430
2002 WRX wagon
Default Which track pads to get?
I'm fading my HP+ pads at this point and I'm trying to figure out which track pad I need...
Looking at the Hawk Blues, Hawk HT-10, and ebc yellows.
This is for shendoah circuit at summit point. It's a fairly low speed track I only get to around 110 and brake down to 50 or so is the biggest speed diff...
Any recommendations?
crofrog is offline   Reply With Quote
Old 07-30-2009, 05:45 PM   #2
MasterKwan
Member#: 98961
2003 WRX
Carbotech XP10's. I don't know the higher end HAWK stuff well enough to comment. Mach-V sells XP8's. They typically have them in stock.
I wouldn't run EBC anything.
When are you going to be out at 'doah? Who are you running with?
Old 07-30-2009, 07:13 PM   #3
rwheelz
Member#: 56697
2008 STI
I will second the XP10's.
rwheelz is offline   Reply With Quote
Old 07-30-2009, 07:25 PM   #4
Robbie_B
Member#: 137728
93 MR2T 87 924S
Teal and Black
I third them.
Robbie_B is offline   Reply With Quote
Old 07-30-2009, 07:45 PM   #5
gregr01
Member#: 49333
04 STi
java pearl black
4th for the Carbotech pads...
though XP8's might do if you use street tires and don't have a great deal of experience, and XP12's might be better if you use R-comps and have lots of experience--though they're tougher on rotors (relatively, I find Carbotech pads to be more rotor friendly than anything else I've used across their line).
gregr01 is offline   Reply With Quote
Old 07-30-2009, 08:06 PM   #6
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
The higher end Hawk stuff is effective, but *really* hard on rotors. I ran Blues for a little while, but never again; having to swap them out to DD was also annoying.
MasterKwan -- didn't you say you DD on the XP10's? Does it have a big effect on your rotor life?
FromageTheDog is offline   Reply With Quote
Old 07-30-2009, 08:31 PM   #7
iLuveKetchup
Member#: 66258
SCCA STU 05 STi #65
I run Carbotech XPs on the s2k. Excellent bite & feel. NO fade at the track. Although the brake dust will stick to the wheels if they get wet.
I've run the DTC line on the STi. OK bite. They are extremely loud!!!! I will replace them w/ Carbotechs when they're done.
iLuveKetchup is offline   Reply With Quote
Old 07-30-2009, 09:54 PM   #8
crofrog
Member#: 57430
2002 WRX wagon
Going out there for the FATT on the 21st and then again with TrackDaze in oct.
Old 07-30-2009, 09:54 PM   #9
crofrog
Member#: 57430
2002 WRX wagon
I'm running RE01R's and should get bumped up to group 2 this time out.
I'm planning on swapping them between track driving and daily driving.
Does Carbotech offer a more aggressive bite compound than the XP10 for the rears?
Old 07-30-2009, 09:56 PM   #10
MasterKwan
Member#: 98961
2003 WRX
Yeah, I dd the XP10's. As gregr01 said, they're not that hard on rotors. I find the HP+ to be far harder on the rotors than the XPs. The XP's are ceramic pads so, the dust isn't corrosive like some other track pads.
I'll probably be there in October too. I'm on vacation on the 21st or I'd do that one too. Group 2 fatt is experimenting with pass anywhere with point, like TrackDaze does in the advanced group.
Old 07-30-2009, 10:26 PM   #11
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
I had the Carbotech XP12 in the front and XP10 in the rears of my STi with StopTech BBK fronts and stock STi rear calipers and I hated the pads. The initial bit seems to be very late. I had a hard time knowing the beginning brake point.
I used to run Hawk DTC-70's and I love them. They are a bit expensive. I'm now on Performance Friction PF01's and see how they are and I'll report back on these pads. They are much cheaper than Hawks.
mug23 is offline   Reply With Quote
Old 07-31-2009, 07:16 AM   #12
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
I'd suggest Hawk DTC-70's or PFC 01's. With street tires you could probably also do PFC 97's.
mav1c is online now   Reply With Quote
Old 07-31-2009, 09:07 AM   #13
mesa50w
Member#: 83044
04.5 blue STi
97 miata, 93 miata turbo
xp 10s in the front and xp8's in the rear and love them
mesa50w is offline   Reply With Quote
Old 07-31-2009, 09:13 AM   #14
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
+1 for the DTC-70's but don't DD on them or you will wear them out quickly. Just track them and you will be very happy.
-Paul
AtomicRacer is offline   Reply With Quote
Old 07-31-2009, 02:01 PM   #15
import111
Member#: 24447
2010 Evo GSR
GG
I would recomend PFC-01's for the track. They hold up VERY well to heat and are very kind to rotors. Best pads I have used on track to date.
import111 is offline   Reply With Quote
Old 07-31-2009, 04:58 PM   #16
joshuaj
Member#: 216249
2011 STI Sedan
XP10s feel fine to me. A bit too much noise for the street though.
This is my 09 WRX with 1400 miles after 1 track day with XP10s.....
joshuaj is offline   Reply With Quote
Old 07-31-2009, 05:05 PM   #17
MasterKwan
Member#: 98961
2003 WRX
Wow, my rotors look nothing like that. Then again, I have brembo's.
Old 07-31-2009, 05:29 PM   #18
REX8
Member#: 24038
You should see a set of blanks after using 12's.
I know we go back and forth about it....again, I love 10's. They truly are easy on rotors, comparatively. But to say they are as easy as street pads...well...some grooving and clear wear should be expect in DD, from my experience.
Old 07-31-2009, 05:30 PM   #19
REX8
Member#: 24038
They wear like the devil though!
Old 07-31-2009, 05:38 PM   #20
joshuaj
Member#: 216249
2011 STI Sedan
The track I was on has 105-25mph haul downs... I'll be doing a BBK after my next track day...
Old 07-31-2009, 05:57 PM   #21
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
I second PFC-01's.
Thumbs down on Carbocrap XP series.
eclip5e is offline   Reply With Quote
Old 08-01-2009, 05:20 AM   #22
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
+1 for Carbotech XP10's
I DD them on the street, haven't in the winter though. They become a bit noisy when the brake quiet melts away, but it doesn't bother me. Their temperature range is also great: I don't have "no brakes" when they're dead cold, maybe just "less brakes" but entirely enough to stop at the end of my street. Once that first stop of the ride has been made you never even notice it again, even on a long highway cruise, there is no issue with that. My silver wheels will get dusted to a new shade of black after a couple weeks but it washes right off.
As someone said above, the bite is tricky, but that seems to be temperature dependent.
Jasonzemos is offline   Reply With Quote
Old 08-05-2009, 12:33 PM   #23
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2015 WRB WRX
Need Brakes? 919.420.0021
I can't believe someone on this board said that
KNS Brakes is offline   Reply With Quote
Old 08-05-2009, 12:58 PM   #24
eclip5e
Member#: 14686
2002 RASpec Impreza
Seconding the PFC's or Carbocrap?
I call it as i see it.
Old 08-05-2009, 01:14 PM   #25
MSP608
Member#: 149631
ST-3 STi
2.3L Evo
How many track weekends are you Carbotech users getting out of your pads?
MSP608 is offline   Reply With Quote
Bedding used track pads to different rotors? Snowphun Motorsports 7 09-24-2008 10:53 PM
Issues going from track pad to street pad on same rotor? wizzman Brakes, Steering & Suspension 5 06-24-2008 11:45 PM
Trying to spray paint to repair anthracite rim... which paint color to get? txl146 Interior & Exterior Modification 0 10-15-2006 11:06 PM
Do I have to change my brake pads to get rid of this brake squeak? chuckly Brakes, Steering & Suspension 8 03-16-2005 05:18 PM
Brakes - what rotors and pads to get? christothes Brakes, Steering & Suspension 5 10-24-2002 04:16 PM
