Old 07-30-2009, 08:51 PM   #1
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Question Need Help!!!
Okay so Im putting my spacers from Jackson Rally in and we got the strut out but now I dont know how to get these bolts out.
When you pull the rubber piece down, the bolts are exposed but the springs will get in the way when you take the bolts out. Any help is greatly appreciated!
Gclark is offline   Reply With Quote
Old 07-30-2009, 10:30 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
WTF are you doing? Why do you need to take the tophat studs out?
Old 07-30-2009, 10:39 PM   #3
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
if you are talking about fitting longer studs into the tophat in order to fit a spacer between the tophat and the strut tower then you will need to remover the tophat from the strut / spring assembly, drive/drill the old studs out, and then reassemble everything
UkNuck is offline   Reply With Quote
Old 07-30-2009, 10:59 PM   #4
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
haha I got a 1in lift kit/spacer from a guy named Jackson Rally on dirtyimpreza.com. It fits on top of the tophat and you need to take the old ones out because there to short.
Old 07-30-2009, 11:00 PM   #5
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Thanks! Thats what I was thinking, but I really wanted to avoid it.
Old 07-31-2009, 08:03 AM   #6
mav1c
Hoodbridge!
Member#: 560
Ahhh...OK. Well...I think you got your answer. And this should be in the suspension forum.
Old 07-31-2009, 08:54 AM   #7
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
oops
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 06:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 09:53 AM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 11:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 01:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 08:57 AM
