Old 05-01-2002, 11:40 PM   #1
jaybyrd
Member#: 18303
02 WRX-dragonwagon
Platinum Silver Metallic
Default 2.2l Turbo
I'm going to get a 97 Impreza L and I want to think about getting a turbo. I read with stock internals you can safely boost about 10 lbs. is this true?
I think also that a garrett Ball Bearing turbo is the best any Comments?
I was woundering if a bumper from a 99-01 2.5RS bumper will fit on the car?
jaybyrd is offline   Reply With Quote
Old 05-02-2002, 12:36 AM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
you can take all of the 99-01 body parts and put them on that car. you just need to change certain ones with each other
ie headlights, grill, hood all must be done at the same time I believe.
Garrett GT25's are NICE turbos if you can fork out 1500 bucks.
And the stock internals will take 10 psi but your injectors wont' like it and neither will your tranny.
Brad
STiTuner is offline   Reply With Quote
Old 05-02-2002, 11:19 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
when you change your bumper you will need to change your front bumper beam..
Old 05-02-2002, 12:53 PM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The headlights and grill fit just fine. You will need a bumper beam.
Turboing any suby is not easy or cheap be prepared to do mucho research.
linsavy is offline   Reply With Quote
Old 05-02-2002, 05:05 PM   #5
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Question
really you need to change the beam??? damn that really sucks, I just bought a bumper
Scoobyslack1 is offline   Reply With Quote
Old 05-02-2002, 05:55 PM   #6
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default cheap
The bumper beam is cheaper than the bumper it' like 100 buck or so. I wouldn't recommend the light wieght one though, I had to get a second one after 2mph impact.
Joshua
yebokmj is offline   Reply With Quote
Old 05-02-2002, 06:00 PM   #7
Scoobyslack1
Member#: 2780
junk yards rule!
Default Re: cheap
Joshua
yeah, but I got a bumper for $50...
Old 05-03-2002, 07:26 AM   #8
peepshow
Member#: 1777
2005 LGT
#92 FZippy
You can always just cut the bumper beam you have. I don't recommend it, but it's been done. The bumper beam is about $75 from Troncalli Subaru, IIRC.
- Trent
peepshow is offline   Reply With Quote
anyone destroked a 2.2l turbo motor to 2.0 l? HighWayDrifter Subaru Conversions 38 07-05-2010 09:39 PM
Looking for info/pics of Legacy 2.2L turbo motor jakeslick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-18-2001 11:02 AM
Intercooler for 2.2L Turbo Prostho Legacy Forum 21 02-11-2001 08:47 PM
2.2l turbo block and 2.5l heads Jessie James Normally Aspirated Powertrain 12 01-23-2001 08:34 PM
Is the 2.2L turbo Cross member the same as a WRX one ? Jay_UK Technical Forum Archive 1 05-27-2000 02:55 PM
