Old 05-02-2002, 04:20 AM   #1
awd1320
Member#: 17563
2002 1320 dogbox
12.052 @ 111.91 stock tur
Default Wastegate problems
My car tonight is acting really strange the wastgate wont open to dump excess boost and i hit 1.4 bar car is ok lucky but im wondering if anyone has had there stock wastegate go out on them , im sure the boost controller is fine any thoughts from anyone?
awd1320 is offline   Reply With Quote
Old 05-02-2002, 09:32 AM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Wastegate problems
What makes you so sure your boost controller is fine? The first thing I would try is disconnecting the boost controller and running with the stock boost control. If the problem persists, then remove your boost controller completely and take the car to the dealer for service.
Jon [in CT] is offline   Reply With Quote
Old 05-02-2002, 09:45 AM   #3
Austin
Member#: 7089
2016 STi
Doubt it's a problem with your wastegate. Probably your wastegate actuator isn't getting the signal it needs, meaning either your boost controller is misadjusted or you have a leak in the boost control system.
Austin is offline   Reply With Quote
wastegate problems james_gt Legacy Forum 9 10-19-2003 10:54 PM
Wastegate problems james_gt Subaru Conversions 0 10-17-2003 08:53 PM
wastegate problem lotusTT Normally Aspirated with bolt-on Forced Induction Powertrain 5 08-07-2003 10:35 PM
HKS wastegate problem Avenger Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-20-2002 01:44 AM
Need help with HKS wastegate problem rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-22-2002 01:34 PM
