#1 |
Member#: 180223
Vehicle:2002 Subaru WRX |
Today was the day we took out the crappy Ej20 and got the EJ22T I am super excited about this build.
![]() EJ22T ![]() Closed deck goodness! ![]() ![]() ![]() ![]() ![]() ![]() Broken head stud! :| ![]()
#2 |
Member#: 180223
Some funny pics!
![]() ASIAN POWA! ![]() Working on the JDM motor ![]() My baby Turbo! mini subie meet ![]() |
#3 |
Member#: 180223
So my parts list consist of:
New Exedy organic Clutch New flywheel DW 1000cc injectors Eagle rods ACL race bearings Wiesco Pistons ARP head studs Mishimoto radiator Eventually a 68HTA turbo for now a VF39 will work my heads will be ported along with my intake manifold done by Subyswamper AKA Jerry |
#4 |
interesting to see another EJ22T block build. I wanna see some head ports!
#5 |
where would one find a ts gt3076r?
#6 |
http://www.atpturbo.com/Merchant2/me...egory_Code=GRT
request for TS v-band hotside, .78A/R only in T3 flange. I want a 1.06 TS option with T4!!! meaning.... it'd have to be GT35R....*sigh* |
#7 |
Member#: 140444
NWIC
Vehicle:05 Legacy GT Wagon ATP 3076 + AVO FMIC |
F'in hilarious pics.
#8 |
Member#: 162469
RMIC
Vehicle:One is silver the other is red |
Ohh wait I make the popcorn and hand it out. Enjoy. |
#9 |
BUMP, any progress with the project? I'm hoping to start a project like this myself soon enough! good luck with the build
#10 |
Member#: 112759
Vehicle:94 Swapped Gc2! Snow covered Black |
Surely by now there has to be some progress?
#11 |
Member#: 180223
Sorry for the delay in updates! but here you go.
![]() ![]() ![]() Grimmspeed EWG Kit. Oh yea.... |
#12 |
Member#: 180223
Thought you guys might want a little update...
#13 |
Member#: 180223
#14 |
Member#: 180223
Awesome port work by Jerry:
![]() Awesome welding and TGV deletes thanks to Zach (fateo66) and Jerry (Subyswamper) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#15 |
Member#: 180223
Heres a semi complete mod list.
ENGINE • EJ22T closed deck short block • Weisco pistons 97.5mm - .020" Oversize • Eagle rods 75mm • ACL race bearings with thrust bearing in #3 • .051 Cometic Head Gasket • 08 STI OEM 11mm oil pump • ARP head studs • Full port job on intake/exhaust/EJ20 heads & manifolds Bolt on engine mods: • Modified WRX blues “800cc” injectors • Perrin V.1 Fuel Rails • SSAC Front Mount InterCooler • VF-39 Turbo • Grimmspeed EWG up-pipe • Tial .1bar 38mm EWG • Koyo radiator • Samco turbo inlet • Samco Hose Kit • Group N motor/trans Mount • Samco MAF hose • APS BOV • Grimmspeed 3-port EBCS • Cosworth timing belt guide • Grimmspeed Phenolic intake manifold spacers • TGV Deletes • Walbro Fuel pump • NGK WRX One Step Colder Spark Plugs • COBB lightweight Pully • Invidia downpipe, Blitz nur spec catback • COBB Heat shield and heat wrap kit. DRIVETRAIN • Exedy Heavy Duty pressure plate • ACT Organic Clutch Disk • Kartboy Short shifter • Goodridge Braided Clutch Line • Scotty’s cocktail fluids SUSPENSION • HKS Hipermax III Sport Coilovers • COBB rear sway bar • Kartboy endlinks • Strut tower bars |
#16 |
I don't know if it's just me... but... looks like pistons #1/3 are upside down. Because i know that the flat part of the pistons are BIGGER on the top than the bottom. Same goes with the heads.
![]() Here are mine. Mine are made to replicate the EJ22T dish, which matches with the flat parts of the Subaru heads. ![]() Here are EJ207 heads combustion chamber ![]() |
#17 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon It goes 12.998 @ 109.44! |
Wiseco pistons have a front and rear, so when you have them on side 1/3, they have to be "upside down"
#18 |
Member#: 180223
#19 |
Member#: 112759
As long as the fwd is facing in the right direction, it doesn't matter if they are up side down,
#20 | |
The green part look like it got more meat than the yellow. But if they have a front to back, then I guess it works! I just had mine made to go with the combustion chamber... so that's why I thought yours would too.![]() ![]() |
#21 |
Member#: 91049
RMIC
Vehicle:1992 tleg, '84tcoupe white, black |
Good pictures on here too YoDannyC. Way to go.
#22 |
Member#: 14116
#23 |
Member#: 162469
RMIC
Engine went in the car late last week.
Started it last night. Started 1st try. Need to button up some things. |
#24 |
Member#: 166324
NESIC
Vehicle:02 Under the Knife dusty |
Video!!!!!!!!!
#25 |
Member#: 180223
