Old 10-22-2009, 08:01 PM   #26
mikebdubsuby
Member#: 209195
2004 Impreza
SRR
Sick build man! Congrats!
mikebdubsuby is offline   Reply With Quote
Old 10-27-2009, 02:29 AM   #27
Yodannyc
Member#: 180223
2012 Wrx
Dark Matter
Its alive!!!!! Drove her home tonight with no issues.
Yodannyc is offline   Reply With Quote
Old 10-27-2009, 02:49 AM   #28
Yodannyc
Member#: 180223
2012 Wrx
Dark Matter
Old 10-27-2009, 07:03 AM   #29
SuperDuper
Member#: 131101
2004 AW STi
Congratulations on your success!!! Great thread also, its helped me out quite a bit as I am also trying to build my Ej22t shortblock to drop into my bugeye.
SuperDuper is online now   Reply With Quote
Old 10-28-2009, 02:53 PM   #30
sorrowfulkiller
Member#: 170439
I <3 Lamp
which pistons and head gaskets did you use? I'm thinking of doing a similar build with ej205 heads this spring!
sorrowfulkiller is offline   Reply With Quote
Old 10-28-2009, 04:35 PM   #31
Built Industries
Member#: 33839
I wish one could still buy the EJ22 closed deck!
Sad, so sad to have to just try and find good used cores (I cannot find anymore, anyone else have any luck?)
Mike Huml
Slowboy -
Built Industries is offline   Reply With Quote
Old 10-28-2009, 04:57 PM   #32
69subaru360
Member#: 159682
1995 WRX
2015 F150
Mike Huml
Slowboy -
I come across them sometimes. I sold the last one I had to a guy in England. For future reference, what do you pay for them?
OP sorry for the hijack, nice work!
Old 10-28-2009, 05:06 PM   #33
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
i got one in my garage..
Old 10-28-2009, 10:49 PM   #34
SuperDuper
Member#: 131101
2004 AW STi
So any idea of what compression ratio it ended up with??
Old 10-30-2009, 12:37 PM   #35
mcandrewsr
Member#: 148756
I just picked up an EJ22T for $200. I may be able to get my hands on another.
mcandrewsr is offline   Reply With Quote
Old 10-30-2009, 02:41 PM   #36
sube-trex
Member#: 97577
2001 IS 300
wow, these are actually good pix doc. a motor build. usually they are .. not as funny 0.0
sube-trex is offline   Reply With Quote
Old 10-31-2009, 06:55 AM   #37
Audioexcels
Member#: 104824
1996 EJ20G OBS
Thumbs up
Originally Posted by Yodannyc View Post
Very beautiful build. Everything looks super clean.
Questions others asked that I'll also ask:
1) Any final compression ratio tests done?
2) Curious why you are using thin head gaskets vs. the regular sized ones? I'm almost positive but the regular sized ones are 3X the thickness of those cosmetic ones. I would be worried about using anything other than the thicker head gasket set, but this is just met.
3) And...how do you like this new engine? Has to be an entirely different car now
Audioexcels is offline   Reply With Quote
Old 10-31-2009, 07:25 AM   #38
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
would have been easier to drop motor back in if
you had it bolted the chain in two places and leveled the motor out some.
but there is always more than 1 way to skin a cat..
Old 10-31-2009, 11:21 PM   #39
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
Yeah. I know this. Do to my lack of motivation to call my friend or go out and buy one, I opted to go the hard way.
ozzy370 is offline   Reply With Quote
Old 10-31-2009, 11:25 PM   #40
69subaru360
Member#: 159682
1995 WRX
2015 F150
I tie an old seat belt to the front intake runners on each side to pull and install subaru engines. It works great.
Old 11-02-2009, 11:17 AM   #41
Built Industries
Member#: 33839
$300-$600.00 depending on how good of shape the block and crank are in.
YES - OP - NICE WORK!
MGH
Old 11-04-2009, 03:23 PM   #42
SuperDuper
Member#: 131101
2004 AW STi
Any updates on the car????
Old 11-11-2009, 05:50 AM   #43
SuperDuper
Member#: 131101
2004 AW STi
Beuller??
Old 11-16-2009, 01:30 AM   #44
Yodannyc
Member#: 180223
2012 Wrx
Dark Matter
Made 270 on 91 oct.
Its amazing what E85 can do.
I need a bigger turbo though eventually.
Really happy with the tune though!
Old 11-16-2009, 04:33 AM   #45
SuperDuper
Member#: 131101
2004 AW STi
Damn!! Thats awesome!! Look at that torque. How much boost?
Old 11-16-2009, 08:45 AM   #46
Yodannyc
Member#: 180223
2012 Wrx
Dark Matter
20psi tapering to 17. Something is not letting it crank out anymore power past 6000 rpm. Which is not a big deal to me cause i like torque! However I think a slightly larger turbo and maybe a set of Kelford cams would make this motor and build even better!
Old 11-16-2009, 09:08 AM   #47
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Interesting power curve. Looks like a stg2 STi power curve. I suppose it's a VF39 so that's expected. I know I can't compare my EVO3-16G-8cm to that.....different turbos.
It's ok if it tapers. Let it. VF39 dies up top. Hotside too small.
FuJi K is offline   Reply With Quote
Old 11-21-2009, 12:57 AM   #48
Yodannyc
Member#: 180223
2012 Wrx
Dark Matter
Old 02-02-2013, 12:48 AM   #49
jmr302
Member#: 216337
2005 LGT
Talking
Back from the dead! This car has changed hands a few times and was parted last spring. I bought the 2.2L engine.
Stay tuned for a new thread as I build it back up.
jmr302 is offline   Reply With Quote
Old 02-02-2013, 10:33 AM   #50
teddyj
Member#: 121796
2005 Blue WRX Sedan
In Subaru I Trust!
Subscribed
teddyj is offline   Reply With Quote
EJ22t hybrid 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-21-2005 12:43 AM
Best Turbo for the Ej22t hybrid benjaminetanyahoo Normally Aspirated with bolt-on Forced Induction Powertrain 27 05-01-2004 07:56 PM
My EJ22T Hybrid GM6! Wedge Member's Car Gallery 29 03-08-2004 03:57 PM
Turbo sizing for EJ22T hybrid help seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 4 06-04-2003 03:12 PM
EJ22T Hybrid Turbo Setup Suggestions seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 18 04-01-2003 11:55 PM
