Old 08-02-2009, 01:31 PM   #1
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
Default Dash lights, hvac lights not working
so, i installed a poineer avic-d3 yesterday and when i went to turn my headlights on, my dash lights all went out. so, i replaced my illumni fuse in the cabin, expecting that to be the problem, but nothing happened. do you guys have another idead of what my problem might be?
iwantmyWRX is offline   Reply With Quote
Old 08-02-2009, 02:24 PM   #2
subywrx
Member#: 81858
Did you try the dimmer switch? Did you connect the red wire from the Pioneer to the correct turn on wire?
subywrx is offline   Reply With Quote
Old 08-02-2009, 03:32 PM   #3
subypal
Member#: 218185
2002 SubyPAL.com WRX
Did you double check your grounds for good contact? When I have problems with electrical I always check grounds.. those lil buggers seem to be the reason every time
subypal is offline   Reply With Quote
Old 08-02-2009, 06:29 PM   #4
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
I'm thinking that's the problem. I'm going to be rechecking the grounds shortly
Old 08-02-2009, 06:38 PM   #5
ocelot21
Member#: 188550
2004 WRX
WRB vf22'd
that or you blew the interior light fuse. i did this once... if grounds are bad check the fuse under the coin tray and ill bet it will work
ocelot21 is offline   Reply With Quote
Old 08-02-2009, 08:16 PM   #6
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
Replaced the fuse and still nothing. Where does the orange illumni wire from the wiring harness go on the back of the unit itself? i dont find an orange one on the back...just organge and white
Old 08-02-2009, 10:38 PM   #7
mems3
Member#: 188617
Chapter/Region: PRSIC
2008 WRX Sedan
this happened once to me and while i was replacing the bulbs and it appears that the wiring in the circuit board blew one of the protective fuses (on the board itself) and i had to re-solder it
mems3 is offline   Reply With Quote
Old 08-02-2009, 11:21 PM   #8
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
Regrounded everything and still no luck. Didn't try replacing the fuse again, so I'll give that a go tomorrow night
Old 01-20-2010, 08:26 PM   #9
I3oostedScooby
Member#: 85390
07 Bmw 335i
TiAg
i know this is old but i just did this yesterday. i was trying to fix one of my leds i have in the hvac and i heard a spark and smelt burning.. but not the hvac and the cluster dont work.. fuse is fine... did i break both circuit boards or are they run in a line or some thing? thanks
I3oostedScooby is offline   Reply With Quote
Old 01-25-2010, 12:13 AM   #10
bradleyski
Member#: 236266
Default No dash lights.
Well you bumped this up. I am also having this problem. Anyone know where the fuse is on the mother board? ( behind the gauges) I looked around for the fuse but did not see one that I could soder. My gauge lights are not working at all. Cant seem to find the problem. I am looking for a new board online but no luck yet. HELP! Thanks
bradleyski is offline   Reply With Quote
Old 01-26-2010, 07:38 PM   #11
I3oostedScooby
Member#: 85390
07 Bmw 335i
TiAg
nothing worked at first for me i took the cluster apart never saw any fuses either put it all back together and now the cluster lights and the radio lights work... still no hvac lights though and nothing works with the dimmer they stay on one brightness... im going to repace the illumination module if i can find one and go from there.
Old 09-21-2010, 11:37 PM   #12
.XS.
Member#: 144708
2007 2.5i
Hello everybody its been a while since i was here.
Just got a 2007 impreza 2.5i.
Today i installed a pioneer deck and when it started to get dark i realized none of my dash lights worked...... when i got home i changed out the deck for the factory and still no dash lights.
did a couple of searches and checked fuse 9 & 12 but they look fine.
any help is greatly appreciated
.XS. is offline   Reply With Quote
HVAC fan not working, need help burnt Electrical & Lighting 1 10-17-2007 01:39 PM
I suck. Dash lights, cluster lights etc. not working, tapped wrong wire lol IIdiceII Interior & Exterior Modification 6 08-17-2007 08:16 AM
HVAC lighting not working garface Electrical & Lighting 2 02-08-2005 02:16 PM
No Dash or HVAC lights Jaker Electrical & Lighting 11 10-20-2004 02:46 PM
brake light on. . drl's not working x12oyx316x Electrical & Lighting 4 07-17-2004 02:11 AM
