Go Back   NASIOC > NASIOC Technical > Factory 2.5L Turbo Powertrain
Old 08-02-2009, 04:50 PM   #1
mrkt321
Member#: 210752
Default Going from rotated turbo back to stock placement, Coolant lines?
My car currently has an element gt65 rotated kit on it. I am downsizing in turbos to a 68hta stock placement turbo. The gt65 has a stainless steel oil line on top like this:
and a line out on the bottom like this:
Will that oil in line work in the new turbo? What other coolant lines do I need to look for? Could anyone send me some detailed pictures of the turbo coolant lines? Any other tips in general with the swap would be helpful as well.
mrkt321 is offline   Reply With Quote
Old 08-02-2009, 05:16 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
The oil feed line should work as long as you get the proper turbo fitting. It may be an adapter -4an to ??? or a banjo bolt and fitting. FP should be able to tell you what you need.
I don't know about the rest though.
Old 08-02-2009, 05:57 PM   #3
mrkt321
Member#: 210752
Ok I was alarmed when I looked back at things and saw that it wasn't a banjo bolt. thanks
trying to go back to stock from viper 5701 cruzinWRX2 Car Audio, Video & Security 8 10-01-2010 09:08 AM
FS (TX): NEVER going back to STOCK sale -- Stock Wheels, Turbo, & Intercooler neorealist TXIC Private Classifieds 7 04-30-2010 01:21 AM
Going back to stock. How to connect boost solenoid vacuum lines? subarujimbo Factory 2.5L Turbo Powertrain 5 08-26-2008 05:23 PM
go back to stock from coilover, help please madcoow Brakes, Steering & Suspension 1 11-10-2006 10:07 PM
Suspsension: go back to stock from coilover, help please madcoow Newbies & FAQs 0 11-10-2006 02:24 PM
Message Board Statistics All times are GMT -4. The time now is 07:55 AM.
