Alaskan Impreza Club
Old 08-03-2009, 12:08 AM   #1
ICEEPUCK
Member#: 174679
2003 WRB WRX
Blue w/ black hoodscoop
Default Coolant leak...
This morning, on my way to work, my belt started to squeal. Turns out, it was coolant leaking from somewhere. Looks like radiator cap/reservoir area. We live in Wasilla, but work in Anchorage, and it was fine for the drive. I'm thinking maybe something just backed up. It was in the first 15 minutes of the car running.(thermostat stuck maybe?) Does anyone know if subarus have any habitual cooling system problems? I looked around and couldn't find much, but when I bought coolant at Schucks, the guy that rang me up said his friend's sti did the same thing. I just don't want the car to shut down on me randomly. Thanks in advance for any help given.
ICEEPUCK is offline   Reply With Quote
Old 08-03-2009, 02:42 AM   #2
Mrs. White
Member#: 207314
63 Impala Wagon
I just saw a black 04/05 sti at a stop light with whitE smoke coming out of the grill yesterday, I hope coolant leaks aren't in the air...
Mrs. White is offline   Reply With Quote
Old 08-03-2009, 02:55 PM   #3
rack
Member#: 32908
2005 Impreza WRX STI
BLUE
My 05 STi has coolant leak, and sqealing belt as well. Conti hasn't been able to see any visual signs of the leaking yet though. While inspecting it, I don't see any either.
It is also only during the first few mins of start up, and the sqealing makes me sound like a beater with a heater =(
If you find out the issue, please post back, I would love to know what may be wrong with my STi.
rack is offline   Reply With Quote
Old 08-03-2009, 03:44 PM   #4
Mrs. White
Member#: 207314
63 Impala Wagon
Nobody has succesfully done a pressure check? Go to a radiator specialist, try Dean's Radiator...
Old 08-03-2009, 09:33 PM   #5
ICEEPUCK
Member#: 174679
2003 WRB WRX
Cracked radiator FTW!!!
found the problem
It was cracked dead center on the top front. Just to the left of the cap. I drove it hard on the way home last night. When I opened the hood, there was a nice little bubble trail about 4 inches long lengthwise on the top.
As for rack, I agree with Mrs. White. Get a pressure test done. They should be able to find it fairly easily. You prolly have a pinhole leak in a hose, possibly even a hole in the core caused by a rock. Honestly, it could be any number of things, so don't quote me. Your best bet is to pony up and have someone do a pressure test.
Old 08-03-2009, 09:59 PM   #6
missiceblast
Member#: 142304
woot major crisis missed!!!
missiceblast is offline   Reply With Quote
Old 08-03-2009, 10:07 PM   #7
ICEEPUCK
Member#: 174679
2003 WRB WRX
Not really, my Jeep has a blown head gasket right now and won't run. I don't have the time to fix it, so I'll prolly just keep adding coolant until the Mishimoto gets here, and I get some time off.
Old 08-06-2009, 04:27 PM   #8
rack
Member#: 32908
BLUE
Conti has done 2 or 3 pressue tests, and looked at it 2 or 3 times.
No luck for me.
Old 08-06-2009, 07:52 PM   #9
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
Fix crack with JB weld or some sort of epoxy. Granted its a temp fix but it will work until you get time to fix properly. I also have a plastic welder if you want to give that a shot.
TurboSetch is offline   Reply With Quote
Old 08-06-2009, 07:57 PM   #10
ICEEPUCK
Member#: 174679
2003 WRB WRX
I already had some epoxy in the car. I threw it on there as soon as I found the crack.
Old 08-06-2009, 09:25 PM   #11
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
if its only during start up, do the suby water pumps have a weep hole? maybe the mating faces arent perfectly flat, and leak when cold but once they expand a bit it quits?
rivman05 is offline   Reply With Quote
Old 08-06-2009, 09:27 PM   #12
Tiene Boost?
Member#: 171826
2003 wrx
2003 wrx radiator is natorious for caracking!!
Tiene Boost? is offline   Reply With Quote
coolant leak, but without the leak iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-30-2003 12:30 AM
coolant leak drboost2002 Bay Area Impreza Club Forum -- BAIC 4 02-07-2002 02:15 AM
serious coolant leak ColinL Normally Aspirated Powertrain 12 11-21-2001 03:48 PM
Coolant Leak KKL Vancouver Impreza Club Forum -- VIC 2 11-03-2001 11:26 AM
