Old 08-03-2009, 10:50 AM   #1
rosss449
Member#: 183969
JBP WRXInfamoustund
SSM 08 STI
Default Gold Rota Torques 17x9?
ive bein loking for a while for gold rota torques 17x9 5x100 or 18x9 has anyone ever came across these? where can i buy them or how can i get them? thanks!
rosss449 is offline   Reply With Quote
Old 08-03-2009, 09:00 PM   #2
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
I think they don't come in gold. Check wheeldude.com. They are a vendor here and a major supplier of Rota rims. I hope this helps.
scooby_wooby is offline   Reply With Quote
Old 08-04-2009, 04:39 PM   #3
rosss449
Member#: 183969
JBP WRXInfamoustund
SSM 08 STI
yeah i looked on wheel dude the biggest size was x8 i jus emailed rota and ill see what they say... on wheel dude they have a special orders section anyone know anything about that?
Old 08-04-2009, 09:22 PM   #4
rosss449
Member#: 183969
JBP WRXInfamoustund
SSM 08 STI
niccce i can special order them from wheel dude but itll take 3 months... im still debating on size though i have a 04 WRX and want to go the biggest i can on S-Techs i do auto x my car occasionaly and dont want that much camber beacuse i want my tires to last... would i be able to do 18x9.5? or would 17x9.5 reduce the camber thanks!!
Old 08-04-2009, 09:47 PM   #5
subiboi624
Member#: 198889
02 SLAMMED WRX
01 FORESTER both Silver
If you do that wide of a tire with a drop you might run into some tire rubbage on you fender well, also the wider the tire the more camber needed to bring the tire in so it does not touch fender
subiboi624 is offline   Reply With Quote
Old 08-05-2009, 12:06 AM   #6
rosss449
Member#: 183969
JBP WRXInfamoustund
SSM 08 STI
if i roll out the fender would that lessen the camber?
Old 08-05-2009, 12:41 AM   #7
grippy monkey
Member#: 131067
your "stance"
sucks
you will have to do that regardless.. and you will still need camber
with a 17x9 +30 you will need -2 in the rear with a nice roll and some pull
Personally on your S-tech springs I would go for rota DPT's or something similar that you can get in a 17x9 +42 range. It is going to be hard to elimate rubbing even with a good bit of work with the springs you have because they are soft and low. In the -2 camber range you will not see abnormal tire wear if you set your toe to 0... you will be fine on that. The issue is that with a 17x9 +30 at lower ride heights you will need a firmer suspension setup, camber, and rolling/pulling. I ran this same setup twice, and setups similar to it a ton of times.
grippy monkey is offline   Reply With Quote
Old 08-05-2009, 11:47 AM   #8
rosss449
Member#: 183969
JBP WRXInfamoustund
SSM 08 STI
so you wouldnt go with the torques 17x9 +30 because of the springs i have it would be hard to elimate rubbing? if all it is, is springs then ill look into buying H techs or something with a higher more stiffer ride... i want to go as big as i can with the torques.... whats the widdest/highest offset i can go with the torques if i replace my springs with stiffer higher ones? if thats the only problem
Old 08-07-2009, 09:44 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
niccce i can special order them from wheel dude but itll take 3 months... im still debating on size though i have a 04 WRX and want to go the biggest i can on S-Techs (mistake number one) i do auto x my car occasionaly and dont want that much camber (this is non sequitur) beacuse i want my tires to last (this is also non sequitur) ... would i be able to do 18x9.5? or would 17x9.5 reduce the camber(final mistake) thanks!!
the above is one of the worst, most unrealistic, things i have seen posted here
total bull**** and proves you need to do a lot more learning before you think you know what you(think) you want(or need)
Old 08-07-2009, 10:49 AM   #10
rosss449
Member#: 183969
JBP WRXInfamoustund
SSM 08 STI
thats why im posting im trying to learn... i did a little more research and if i get the Eibach sportline springs and set my toe to 0, set -2 camber, roll all my fenders, and put 245's all around 18x9.5 would fit fine... i dnt auto x all the time maybe a couple times a year... crutique me on that thanks
Old 08-07-2009, 09:06 PM   #11
monkiboy
Member#: 202958
2008 wrx
holy flame batman...i'm glad i dont ask questions on here...yikes!
rosss449 - good luck on your aggressive set up. luckily enough there are other resources available then thinking folks might want to aide you through this specific public sharing domain...
monkiboy is offline   Reply With Quote
Old 08-07-2009, 09:53 PM   #12
TeamTHP
Member#: 151994
05 STI "Stage 2"
[email protected], 1.78 60's
Wow, this is sad. "Guru" My left nut. calm down man.. not everyone online "Know as much about cars" as you. I hope you don't act that way to your Nieces and/or Nephews.
I see you post on here a lot. And the only reason I notice is, a majority of the time your giving this message board a bad name.
Seriously sad.
TeamTHP is offline   Reply With Quote
Rota Torque 17x9 +30 jgartland Tire & Wheel 7 05-27-2009 11:16 PM
WTT Rota torques 17x9 5x100 rafacz2002 Wheels/Tires 5 03-18-2009 12:18 AM
FS: Brand New FRSB Rota Torques 17x9 5x100 +30 rmarchigiani MWSOC Private Classifieds 6 03-06-2009 10:50 AM
FT TW: rota torques 17x9 w/falkens kendostick Wheels/Tires 19 01-25-2009 10:07 PM
