Old 08-03-2009, 01:03 PM   #1
cam.rex.03
Member#: 192104
2003 WRX
Midnight Black Pearl
Default where does this O-ring go?
I was flushing my coolant yesterday, took off undercover and drain plug, that's it. Looked under my car after finishing up and found an o-ring, looked just over a half inch in diameter, and it's black. Any ideas on where this came from? (I'm thinking drain plug, maybe?)
AHHHH!!
cam.rex.03 is offline   Reply With Quote
Old 08-03-2009, 01:38 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Is it flat? Or is it a real "O" ring. IIRC, the one on the drain petcock is black rubber, and flat like a washer. It may not leak even with it off.
z&cobb is offline   Reply With Quote
Old 08-03-2009, 03:12 PM   #3
cam.rex.03
Member#: 192104
2003 WRX
this o ring is a real one, cylindrical
Old 08-03-2009, 07:36 PM   #4
z&cobb
Member#: 12344
2002 2JC
blue
Manuals, Section 8, Page CO-9 shows a washer like thing or O ring in the diagram, so if you did not put one back on, that's probably what's shown on the page. It's shown but not identified or drawn very well.
Help! where does this vacuum line go?! scritchy Factory 2.0L Turbo Powertrain 8 01-09-2009 01:41 PM
Where does this vacuum hose go? mlovro32 Factory 2.0L Turbo Powertrain 6 06-18-2007 06:00 PM
Help. Where does this Vaccum Hose go? ProdriveRex Factory 2.0L Turbo Powertrain 4 04-07-2006 11:17 AM
Where does this ground wire go?! helievacpilot Factory 2.0L Turbo Powertrain 1 01-13-2006 01:18 AM
Where does this Vacuum Line Go? scoolbuzz Factory 2.0L Turbo Powertrain 4 09-27-2004 01:58 PM
Message Board Statistics All times are GMT -4. The time now is 01:58 AM.
