Old 08-03-2009, 04:43 PM   #1
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Question VW 5x100 wheel fitment - centerbore question
The Subaru hub for 56.1mm centerbore wheels. People running wheels meant for VWs (57.1mm)... did u use any centering rings, and if so where did u even get a 1mm thickness ring? Also, if u don't use one.. is there any possible vibration issues that I may be looking at??
TIA!
Torquey is offline   Reply With Quote
Old 08-04-2009, 01:09 PM   #2
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
anyone?
Old 08-06-2009, 07:43 PM   #3
Torquey
Member#: 175334
2003 Impreza WRX
JDM v8 EJ207 WRB
Still need this info...
Old 08-11-2009, 11:32 AM   #4
kennyvb
Member#: 70234
MY86 BMW E30 325
SCIC/NWIC tranplant (-_-)
the ring you'd want would be 0.5mm thick. doubt anyone makes that. you can always get it bored larger (ie. 73mm like a lot of aftermarket wheels) and get the appropriate ring. i'd just run it non-hubcentric making sure you torque down the wheel in a star pattern.
kennyvb is offline   Reply With Quote
Old 08-11-2009, 06:33 PM   #5
thrasher
Member#: 40579
2002 WRX Stage 2+
Tuned by IA Performance
PM AVAWRX...he runs 18" OEM BBS wheels from a Jetta on his 06/07 WRX.
thrasher is offline   Reply With Quote
Old 08-11-2009, 09:35 PM   #6
Legacy
Member#: 10188
2007 Forester XT
Just cause a wheel slides onto a Subaru doesn't mean you should run it. Those little things like "offset" and "bearings" matter. But then again, if you're into the HELLA-FLUSH look go ahead and bolt 'em up. What could possibly go wrong ?
Legacy is offline   Reply With Quote
Old 08-11-2009, 09:57 PM   #7
grippy monkey
Member#: 131067
your "stance"
sucks
^ I'm pretty sure the 7.5" wheels he's talking about are hardly going to be hellaflush... but nice try at taking a stab at it.
There is a few members on Nasioc running 18x7.5 +35 VW takeoffs. They fit really easily on our cars with little if any work, and your wheel bearings are hardly an issue with those specs. 9" in +38 to +45 is pretty standard on Subaru's and there would be more stress with those specs than the wheel he is talking about.
The wheel bearing discussion is pretty lame anyways. I would do some more research on the billions of threads about it before posting.
I would just stop driving all together... you wouldn't want things like your brakes or wheel bearing to ever begin to wear down.
grippy monkey is offline   Reply With Quote
Old 08-11-2009, 11:15 PM   #8
rougeben83
Member#: 115154
2005 Outback XT
White on grey
As long as you tighten your lugnuts in a star pattern in stages *with the wheel off the ground* (doing the final torque with weight on the wheel), centering rings shouldn't really be needed.
rougeben83 is offline   Reply With Quote
What do you think? Wheel swap in question! stierzy34 Interior & Exterior Modification 23 06-05-2010 06:01 PM
WTB Set of wheels 5x100 17x8 fitment for 4pot/2pot whatishe Tri-State Area Private Classifieds 9 01-02-2010 12:36 AM
Wheel fitment question on Sti's crystalhelix Interior & Exterior Modification 3 02-25-2004 11:27 PM
Dumb question...about tire to wheel fitment philw007 Tire & Wheel 7 12-14-2003 01:00 AM
BE/BH Wheel fitment question leeberbs Legacy Forum 4 11-07-2002 02:36 PM
