Old 05-09-2002, 11:13 PM   #26
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Seems like that should be worth some IggPoints....
blaster88 is offline   Reply With Quote
Old 05-09-2002, 11:27 PM   #27
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
You mean this gold thing on the left side?
You should be able to order it from any dealership. Although, I don't think it is the same diameter as the oil drain plug. I believe it is a bit wider.
Revision is offline   Reply With Quote
Old 05-10-2002, 08:08 AM   #28
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Last night, I successfully modified my extra oil drain plug to fit a AN -8 fitting. It is looking good coz now I can use SS braided lines for the job. No need to buy that gold thing on the Forester. and you're right, it looks too big for the job anyway.
Now all I need is a 5/8" "Tee" for the return line to tee into the heater core return line. This setup should eliminate any worries of the heater core shut off valve. Thanks!
Boostup! is offline   Reply With Quote
need upper coolant line for turbo t4nk AKIC Private Classifieds 0 09-13-2008 04:53 PM
Removing coolant reservoir for turbo... Joey_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-18-2005 04:44 PM
Oil/Coolant connections for turbo SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-19-2003 12:08 PM
Single Source for Turbo prices and specs -=C=- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-24-2001 05:03 PM
Sources for turbo ready 2.5 block? geronimo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-27-2001 09:28 PM
