Old 08-03-2009, 09:05 PM   #1
bluert
Member#: 126959
Default EcuFlash error message/can't read ecu.
This is for an 05' STi. I had it tuned couple years back by a tuner using open ecu/ecuflash. So today I tried to reload the stock map but I keep on running into the same error code when I tried to read the stock ecu. I tried reloading the stock map but that doesn't work either which I was not suprised. I've searched and done all the common mistakes such as loose connection, not turning on the ignition at the proper time, etc..
Here's the error message:
*Using interface OpenPort 1.3 Subaru
*TX46P7s11b6cb4d53c44cfald41cacc8774ccd7c4ee5e4cc
*SSM2 init
*SSM2ECU ID is 3D12 59 40 06
*Requesting Seed....
*interface close
*interface close
I did this more than 30 times with the same result. Could it be that I got the wrong cable from Tactrix?
Here's a pic of the cable. I highlighted the pins with white dots so it's easier to see.
The tuner has his own cable at the time and I'd bought mind over a year ago and had never used it until today.
Any help is appreciated.
bluert is offline   Reply With Quote
Old 08-04-2009, 07:07 AM   #2
quazimoto
Member#: 70395
Which version of Ecuflash are you using?
quazimoto is offline   Reply With Quote
Old 08-04-2009, 12:39 PM   #3
bluert
Member#: 126959
version 1.34.1435
Old 08-04-2009, 06:36 PM   #4
bluert
Member#: 126959
I tried the lastest version 1.42 with the same result.
Old 08-08-2009, 07:10 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
please remember after you select the read option to
activate the ok option asap when you tunr ignition switch..
with 2 seconds..
Old 08-08-2009, 01:42 PM   #6
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
My car only works if I do the "OK" and key turn in the opposite order that the EcuFlash tells me to. Try that and see what happens.
Old 08-12-2009, 06:38 PM   #7
bluert
Member#: 126959
with 2 seconds..
I tried that. Did it in less than 2 seconds in numerous times.
Old 08-12-2009, 06:40 PM   #8
bluert
Member#: 126959
You mean turn the key towards you as oppose to the indirection of starting your engine? I will give that a try when I get my car back from the shop in a few weeks.
ERROR trying to read rom - ECUFLASH GURUs HELP SuperSTI Open Source Reflashes 7 07-02-2009 12:41 PM
Ecuflash can't read 2.5RS? formula91 Open Source Reflashes 0 04-24-2009 02:44 AM
Can't read ECU jarencibia Open Source Reflashes 2 10-17-2008 11:48 AM
Problem reading ECU with ECUFLASH Subyroo2.5 Open Source Reflashes 3 02-10-2008 10:02 AM
need help! can't read ecu thru ECUFlash sgmongoose Commercial ECU Reflashes 9 08-08-2007 11:58 AM
