08-03-2009, 10:09 PM | #1 |
Member#: 206939
SWIC
Tranny same as Rear Diff Fluid??
Hey guys, this is gonna be a reaaaaaaaaaaally stupid question, but im very serious and need some help...
Im about to do my tranny fluid change, and I decided to go with Redline Shockproof tranny fluid. I just wanna know... the 75W 95 fluid im using for the tranny fluid I can put in the rear differential fluid as well, correct? And cause no harm? Its pretty much the same thing, correct? Sorry for such a stupid question... I just need some help, I figure I would ask instead of ****ing something up Thanks in advance
08-03-2009, 10:48 PM | #2 |
Member#: 71903
Vehicle:11 Audi A4 6MTQ 13 Mazda CX-5 |
you want a fluid for the rear diff with an additive, a "friction modifier" for the LSD. i don't see that shockproof meets the needs according to redline's website. if you want redline, you want 75w90 for the diff
http://www.redlineoil.com/products_g...bCategoryID=16 |
08-04-2009, 12:01 PM | #3 |
Member#: 206939
SWIC
thank you for that info
so what would other recommend, i heard Motul thrown around a few times? and what specific gear oil do i need for the tranny and for the rear diff? are they be used as the same fluid regardless of what brand i use? |
08-04-2009, 01:34 PM | #4 |
Member#: 12344
Vehicle:2002 2JC blue |
If it is Redline, their recommendation for my car, is 75w90NS in the transmission and 75w90 in the rear differential. It has worked for me and kept the "glass" gears from shattering.
I have been told that Motul is good. I know of only one problem with a Legacy GT with Motul in the transmission, but I refain from placing blame on the basis of a single instance. Some could say something like that for Redline or Uncle Scotty's cocktail. You pays your money; you takes your chances. |
08-04-2009, 02:45 PM | #5 | |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
Read your owners manual. The WRX rear diff does not need friction modifiers it is not a clutch type rear diff, its a viscous coupling. 75w90 is what goes in the WRX rear diff. The only WRX that needs different rear diff oil are certain year STi vehicles that need Subaru LSD Oil. sheesh. |
08-05-2009, 07:50 PM | #6 |
Member#: 71903
I do read the owners manual. (Ironically I work for an OEM vehicle manufacturer and I create tech manuals). I read it cover to cover when I bought the car (really). My WRX's owner's manual, page 11-23 only says to use a GL-5 oil and not to mix different brands together.
That doesn't matter since I mistakenly thought the OP had an STI. But since you were such a polite contributor, perhaps you could be so generous to tell everyone why you first discredited me without offering the benefit of the doubt, THEN recommended not only the same oil as I but the one that happens to contain the friction modifier package anyway? Everyone's a keyboard engineer. Or maybe they call them gurus now? SHEESH |
08-06-2009, 09:53 AM | #7 |
Member#: 116052
Vehicle:2011 STI ( Sold ) WRB |
for wrx...
put motul 300 straight front and rear and forget about it.... |
08-06-2009, 10:44 AM | #8 |
Member#: 4273
NESIC
Vehicle:2015 Taco & 2015 Legacy Ltd. |
The rear differential at least on my 2006 WRX is a viscous type sealed unit. This utilizes a viscous silicone fluid which is sealed from the rest of the gear oil in the differential...
That being said, stick with GL-5 rated fluid and fill up the transmission/front diff and rear diff with it... I use ENEOS and it has made shifting feel butter smooth on my 5 spd and absolutely awesome on my buddy's '07 STI. *The only STI/ STi's that should need the friction additives are the ones with 'plate-type' LSD's. |
08-08-2009, 07:06 AM | #9 |
Member#: 133416
South East
fluid
You could also use the "real deal" Extra S from Subaru. I have some in the bulk container available. Sorry for the shameless plug.
08-09-2009, 07:58 PM | #10 |
Member#: 206939
SWIC
08-10-2009, 09:43 AM | #11 |
Member#: 4273
NESIC
Power steering fluid, manual tranny fluid, and rear diff fluid | ex_boyometric | Vancouver Impreza Club Forum -- VIC | 17 | 03-09-2008 05:54 AM |
Tranny Fluid and Rear Diff Fluid? | Stellar1 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 03-07-2005 12:22 AM |
Rear diff fluid & tranny fluid | rich22 | Service & Maintenance | 7 | 05-06-2004 10:04 AM |
WTB: Redline Tranny fluid and Rear Diff fluid | RimRockaz | Bay Area Impreza Club Forum -- BAIC | 11 | 07-16-2002 03:19 PM |
Tranny and rear-diff fluid change experience | jlyttle | Transmission (AT/MT) & Driveline | 19 | 04-29-2002 04:57 PM |
