Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 04-12-2001, 01:04 PM   #1
Member#: 3886
2011 STi Sedan
Mancream White
Question What's the official method to reset ECU?
I've heard different things, so I wanted a real answer. Is this a good thing to do anytime you change the breathing characteristics of your car?
Brood is offline   Reply With Quote
Old 04-12-2001, 01:12 PM   #2
Member#: 1685
2001 2.5RS-T FMIC
I just reset it for the hell of it. Its a simple thing, just take the NEGATIVE cable off the battery, let the car sit powerless for an hour or so, than put it back. Start the car (mine never stars after a reset), and let it idle. Don't touch gas or anything else. Than shut it, and turn it on again, and drive it around.
Or something close to whatever I said above. Its not a big deal.
bigbird is offline   Reply With Quote
Old 04-12-2001, 01:20 PM   #3
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
trhe first time starting it after connecting the battery, make sure to let the engine get to normal running temp without touching the gas...then it's safe to shut off. After that, you can just go.
JGard is offline   Reply With Quote
Old 04-12-2001, 01:21 PM   #4
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
The OFFICIAL method, as in the only one recognized by SOA or a dealer, is to reset it with the Subaru Select Tool.
But yes, what our yellow friend mentioned is the correct "end-user" way.
ColinL is offline   Reply With Quote
Old 04-12-2001, 02:09 PM   #5
Primm Motorsports
Member#: 2098
There is a quicker method that will not take an hour. Disconect the battery then step on the brake pedal to discharge the electrical system, replace the battery cables and your are done. As mentioned above, start the vehicle without touching the gas.
Primm Motorsports
Primm Motorsports is offline   Reply With Quote
Old 04-12-2001, 02:32 PM   #6
Member#: 5311
2004 GTO 11.2 @ 123
Was 4EAT '02 WRX [email protected]
Quick newbie questions: why and when should I reset the ECU? (I have searched the forums but haven't found anything that explains it in newbie terms.) I'm still in break-in, so I don't want to mess with anything. After 1k miles or so, what benefits will resetting the ECU give me?
Thanks for being patient with a newbie
PadreWRX is offline   Reply With Quote
Old 04-12-2001, 02:38 PM   #7
Ghost Mod
Member#: 1278
2001 RS
An ECU reset is helpful (not required) after a performance mod is added to your car. It allows the ECU to learn more quickly, rather than over time. Also, after a re-set you want to drive your car "briskly".
SkToBe is offline   Reply With Quote
Which is the correct way to reset the ECU?? z28dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-26-2002 07:15 PM
How to reset ECU without setting off the alarm? toerag Newbies & FAQs 2 01-28-2002 01:16 PM
What's the best method to shift smoothly? Sooberman Newbies & FAQs 12 06-07-2001 08:44 PM
('93-'01) Which is the correct/better way to reset ECU? bensonwrx Impreza Forum 13 05-29-2001 02:39 AM
('93-'01) Other method to Reset ECU?.. please chinaman Impreza Forum 0 05-24-2001 01:07 PM
